    Svenskalag.se
    5 Posts 2 Posters 1.8k Views 2 Watching
    • H Offline
      Henrik
      Hello!
      Has anyone integrated the “invititations” (kallelser) from svenskalag.se into their Magic Mirror? (Svenskalag is a site for keeping track of your kids’ football trainings & matches, etc.)
      They do provide a calendar export function, but it will show you every training by every team in the club, making it useless. I want to see just my kids’ trainings, and just the ones they will actually attend.
      I am pondering creating a simple scraping thingie that will in the end produce an .ics , which will be consumed by the Calendar Module.
      Thoughts on this?
        sdetweil @Henrik
        @Henrik you might be able to use the excludedEvents:property to remove all the other
        also, if you pull down the ics , it is just a text file… so this might make cleaning easier
        curl -sL the_cal_url >somefile.txt
        then u can look at filtering out events
        they start with
        BEGIN:VEVENT
        and end
        END:VEVENT
        final file needs a BEGIN:VCALENDAR/END:VCALENDAR around the VEVENTs
        • H Offline
          Henrik @sdetweil
          @sdetweil Thanks, however that file does not contain info on how we have responded to the invitations! (e.g., are we attending the training/match in question?)
          I’ll have to do the scraping, I believe.
          • H Offline
            Henrik @Henrik
            I have now had time to wrap this up! It’s not a MM module, but a combination of shell and python scripts that in the end produce ics files, that are then consumed by the Calendar module. Works like a charm so far.
            In case this’d be useful to anyone else, just ping me and I’ll share the details.
              sdetweil @Henrik
              @Henrik nice work
