    Module not showing up
    16 Posts 2 Posters 3.8k Views 2 Watching
      basho429
      Hello. I am new to MagicMirror. I installed it on my Mac mini and I got the default calendar, weather, news, and compliment modules working.
      I installed a different weather module (git cloned and npm installed). I added the new module to my config file. I ran the config check and no errors were found. However, when I ran Magic Mirror, I don’t see the new module.
      Any suggestions?
      Thank you.
        sdetweil @basho429
        @basho429 can u show the part of config.js for that module. xxx out any API key
        what module is it?
          basho429 @sdetweil
          It is the MMM-OpenWeatherMapForecast module.
          I copied the sample configuration from the github page (providing my own apikey, changing the header, latitude, and longitude). However, all I see is the header and “Loading…”
          All the other modules are running (default weather, compliment, news, clock, and calendar).
          On Terminal, I see two lines that pertains to MMM-OpenWeatherMapForecast.
          1. Checking git for module: MMM-OpenWeatherMapForecast
          2. [MMM-OpenWeatherMapForecast] 15-Dec-22 10:23 ** ERROR ** null
          Any idea what these means? Any suggestions on how to fix it?
          Thank you.
            basho429
            Here is my module config:
              module: "MMM-OpenWeatherMapForecast",
              header: "MY CITY",
              classes: "default everyone",
              disabled: false,
                apikey: "MY OWN APIKEY",
                latitude: "MY LATITUDE",
                longitude: "MY LONGITUDE",
                iconset: "4c",
                concise: false,
                forecastLayout: "table"
              sdetweil @basho429
              @basho429 edit the module node_helper.js and change this
                                  if (!error && response.statusCode == 200) {
                                      //Good response
                                      var resp = body; //needle automagically parses the response as JSON
                                      resp.instanceId = payload.instanceId;
                                      self.sendSocketNotification("OPENWEATHER_ONE_CALL_FORECAST_DATA", resp);
                                  } else {
                                      console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** ERROR ** " + error);
              to this
                                  if (!error){
                                      // Good response
                                      if(response.statusCode == 200) {
                                          console.log(" needle responding="+JSON.stringify(resp))
                                      else {
                                          console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** bad status ** " + response.statusCode);
                                  } else {
              then restart MagicMirror, and look at the messages again
              at least u will get a good error report
                sdetweil @basho429
                @basho429 on your config…
                please always use the code block marker for config info.
                paste your text
                select it all
                hit the button above the editor that looks like </>
                u can edit the existing post and change it
                  basho429 @sdetweil
                  I changed the module node_helper.js and restarted MagicMirror. However, I am still not getting any new error message. It’s still the same NULL error. Can you please check below and see if I changed it properly? Thank you.
                  /* Magic Mirror
                   * Module: MMM-BMW-OW
                   * By Mykle1
                   * MIT Licensed
                  const NodeHelper = require('node_helper');
                  const request = require('request');
                      start: function() {
                          console.log("Starting node_helper for: " + this.name);
                      getWeather: function(url) {
                          request({
                              url: 'https://api.openweathermap.org/data/2.5/onecall?lat=' + this.config.lat + '&lon=' + this.config.lon + '&units=' + this.config.units + '&lang=' + this.config.language + '&appid=' + this.config.api,
                              method: 'GET'
                          }, (error, response, body) => {
                              if (!error){
                                          // Good response
                                          else {
                          if (notification === 'GET_WEATHER') {
                              this.getWeather(payload);
                          if (notification === 'CONFIG') {
                              this.config = payload;
                    sdetweil @basho429
                    @basho429 that is not the changed new code… that is the old code
                      basho429 @sdetweil
                      Below is the complete module node_helper,js that came with the module. Can you please send me back what it should contain to get more info about the error? Thank you.
                      /* Magic Mirror
                       * By Mykle1
                       * MIT Licensed
                          start: function() {
                              request({
                                  method: 'GET'
                                      var result = JSON.parse(body);
                                      //	console.log(body); // for checking
                                      this.sendSocketNotification('WEATHER_RESULT', result);
                        sdetweil @basho429
                        @basho429 ok, we are talking different modules now
                        that is the MMM-BMW-OW module
                        to get its helper back, in that module folder do
                        git checkout node_helper.js
                        my code goes in the node_helper.js for MMM-OpenWeatherMapForecast module only
                          basho429 @sdetweil
                          Apologies for the mix-up. Noob mistake. I was looking at the wrong node_helper.js. I changed the correct node_helper.js and got an error message that says ** bad status ** 401. What does that mean? Thank you.
                            sdetweil @basho429
                            @basho429 401 is authorization error… so your api_key is not good…
                            we had to make a change in the default module that uses openweathermap
                            try changing this
                            "https://api.openweathermap.org/data/2.5/onecall"
                            to this
                            "https://api.openweathermap.org/data/3.0/onecall"
                              basho429 @sdetweil
                              I am using the same api key for the default weather module that came with MagicMirror (and it works fine). Does that mean I need separate api keys for separate modules? Or I can only use one weather module at a time?
                              I made the change from 2.5 to 3.0 on the node_helper.js.
                              Thank you.
                                sdetweil @basho429
                                @basho429 did the change make a difference?
                                I do not know otherwise
                                  basho429 @sdetweil
                                  I created a new api key but I am still getting a 401 error.
                                  I will remove the module and re-install. Maybe that will work.
                                  Any suggestions?
                                  Thank you.
                                    sdetweil @basho429
                                    @basho429 reinstalling the module won’t help
