    Module not showing up
    16 Posts 2 Posters 3.5k Views 2 Watching
      basho429 @sdetweil
      Apologies for the mix-up. Noob mistake. I was looking at the wrong node_helper.js. I changed the correct node_helper.js and got an error message that says ** bad status ** 401. What does that mean? Thank you.
        sdetweil @basho429
        @basho429 401 is authorization error… so your api_key is not good…
        we had to make a change in the default module that uses openweathermap
        try changing this
        "https://api.openweathermap.org/data/2.5/onecall"
        to this
        "https://api.openweathermap.org/data/3.0/onecall"
          basho429 @sdetweil
          I am using the same api key for the default weather module that came with MagicMirror (and it works fine). Does that mean I need separate api keys for separate modules? Or I can only use one weather module at a time?
          I made the change from 2.5 to 3.0 on the node_helper.js.
          Thank you.
            sdetweil @basho429
            @basho429 did the change make a difference?
            I do not know otherwise
              basho429 @sdetweil
              I created a new api key but I am still getting a 401 error.
              I will remove the module and re-install. Maybe that will work.
              Any suggestions?
              Thank you.
                sdetweil @basho429
                @basho429 reinstalling the module won’t help
