    Attempted to add MM-Remote-Control, now MagicMirror won't start
    4 Posts 2 Posters 918 Views 2 Watching
      monkeyjb123
      Hello everyone! I don’t have much experience so bear with me on this but I was setting up my MM when I decided to add in the MM-Remote-Control module. It took a while but after some tinkering I was able to get it to work via my phone by changing the ipWhitelist section to:
      ipWhitelist: [],
      Seemed to have work and was able to shutdown my pi with my phone. After rebooting and making some updates via the remote control to two modules I have, the mirror stopped working and no longer runs. I tried to restart the mirror as well as the pi but still does not work. This is the error message I receive
      pi@raspberrypi:~/MagicMirror $ npm run start
      > magicmirror@2.21.0 start /home/pi/MagicMirror
      /home/pi/MagicMirror/node_modules/electron/index.js:17
          throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again');
      Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
          at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:17:11)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/index.js:21:18)
          at Module._compile (internal/modules/cjs/loader.js:778:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          at Module.load (internal/modules/cjs/loader.js:653:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          at Module.require (internal/modules/cjs/loader.js:692:17)
          at require (internal/modules/cjs/helpers.js:25:18)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/cli.js:3:18)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.21.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.21.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2022-12-17T20_57_05_651Z-debug.log
      I previously had the MM autostart with pm2 but it no longer does this. Would appreciate any help.
        sdetweil @monkeyjb123
        @monkeyjb123 said in Attempted to add MM-Remote-Control, now MagicMirror won't start:
        do
        cd  ~/MagicMirror
        rm -rf node_modules/electron
        npm install electron@19.1.0
          monkeyjb123 @sdetweil
          @sdetweil Thank you! Just did that and it is auto-running again. Some modules like the weather are no longer showing up and the font has changed on the mirror
            @monkeyjb123 I don’t know what you did before.
            I never use rmc to do updates
            what does the pm2 log show?
