    MM with Google Calendar do not refresh events after time refresh
    3 Posts 2 Posters 397 Views 2 Watching
    • E Offline
      ejgcos
      When MM starts it display correctly all events in Google Calendar.
      After that if i remove an event or add a new event in Google Calendar, MM do not show the change after the refresh time.
      Note: i am using the private URL
      Will be possible an help ?
      Thank you
        sdetweil @ejgcos
        @ejgcos this should work. the default refresh time is 5 minutes.
        mine refreshes without issue.
          sdetweil @ejgcos
          @ejgcos if you do
          curl -sL calurl >somefile.txt
          using the url u have
          u can edit and look for the new event…
          BEGIN VEVENT
          END VEVENT
