    After restart and updating raspberry MM will not starting
    11 Posts 2 Posters 3.7k Views 2 Watching
      aldisachen
      Hello, I have a Raspi 4 with the following system:
      • Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
      • Docker version 20.10.21 and Poratiner version 2.12.2 are installed on it.
      • Magic_Mirror is also running as container on portainer
      Now to my problem…
      Every time if I restart the Raspi or install updates and restart the Raspi the MM will not longer working.
      Currently solution to workng again:
      • delete the container in the Portainer
      • delete the volume in the container
      • delete directory directly on the Raspi using rm -r “Magic_Mirror” (including the subdirectory.
      After these steps I use the next spets to running MM again:
      docker run -d
      –publish 8181:8080
      –restart always
      –volume ~/magic_mirror/config:/opt/magic_mirror/config
      –volume ~/magic_mirror/modules:/opt/magic_mirror/modules
      –volume /etc/localtime:/etc/localtime:ro
      –name Magic_Mirror
      bastilimbach/docker-magicmirror
      In order for MM to run, I have to change the network connection of MM from “Bridge” to “Host” in Portainer. Then MM runs again. Why is that and where can I see why MM is causing difficulties? It’s annoying having to do the above steps every time you install updates and have to restart the device.
      Other containers are running without problems after restart. It´s only the MM with the problems.
      Thanks in advance.
        sdetweil @aldisachen
        @aldisachen said in After restart and updating raspberry MM will not starting:
        address: “localhost”,
        this is a problem…
        it means ONLY apps INSIDE the same system can connect. ie, from INSIDE the container
        you want apps OUTSIDE the container to connect, the docker host or further away.
        so you should change that to address:“0.0.0.0”,
        meaning over any network interface, without having to specify what it is.
        then you can run container in network bridge mode. it will get IP address 172. something…
          @aldisachen this is a duplicate. don’t double post
            aldisachen
            Hello and sorry for this misstake,
            Please delete the other duplicate post. Sorry again. Thanks.
              @aldisachen done
                @aldisachen what is the address: setting in mm config.js?
                what url do you use to access mm?
                  aldisachen
                  Hello all togehter, the config.js starts with:
                  /* Magic Mirror Config Sample
                  • By Michael Teeuw http://michaelteeuw.nl
                  • MIT Licensed.
                  • For more information how you can configurate this file
                  • See https://github.com/MichMich/MagicMirror#configuration
                  var config = {
                  address: “localhost”, // Address to listen on, can be:
                  // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
                  // - “0.0.0.0” to listen on any interface
                  // Default, when address config is left out, is “localhost”
                  port: 8080,
                  ipWhitelist: [], // Set [] to allow all IP addresses
                  // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                  // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                  and it will follow with the language, time format and so on and so on witch all the settings to display for the MM. Thnaks.
                    this is a problem…
                      aldisachen
                      Hello, I don´t understand what is nessssary to change in the config file. Can you please write down the right settings at the config file ?
                      I have no experience with that. Thanks.
                        @aldisachen I did,
                        address:"0.0.0.0",
                          aldisachen
                          Hello together,
                          after change the Address from “localhost” to “0.0.0.0” and restart the MM is runing without problems.
                          Now I can update and upgrade the system every day and not every month. It was not funny to do the same steps after restart and running the MM again. Thank you very much.
                            @aldisachen cool… glad u got it…
