    Mirror broken after v2.22.0 upgrade
    29 Posts 4 Posters 11.1k Views 4 Watching
    • P Offline
      Peter
      @ecirpnaes said in Mirror broken after v2.22.0 upgrade:
      My problem is resolved. I upgraded to bullseye and reinstalled the mirror. I used your alternative install script vs cloning manually. It worked flawlessly setting up the mirror and the pm2 autostart. So many thanks for that.
      I think I spent more time getting the mirror to rotate properly than anything else. File locations have changed for bullseye vs some of the older versions so it took a little hunting around to get things configured.
      But all good now. Thanks again!
      Here everything works fine now except rotation of the screen …
      Somebody have an idea?
      I tried display_rotate=1 in config.txt; it looks good but as soon as MM starts the screen rotates back to the left.
      Peter
        sdetweil @Peter
        @Peter use the preferences, top left on desktop, display rotation
        • P Offline
          Peter @sdetweil
          @sdetweil preferences gives the same problem: screens turns back to normal after restarting MM.
          I am trying custom CSS now (saw it somewhere).
          Keep you informed.
          Peter
            sdetweil @Peter
            @Peter take your stuff out of config.txt
            • P Offline
              Peter @sdetweil
              @sdetweil did that.
              Custom CSS did not do the job!
              The search goes on.
              Peter
              • P Offline
                Peter @Peter
                I think it is a problem with V2.22.0
                Before updating to this version everything worked fine.
                I made a fresh OS and MM install a few weeks ago.
                It was running fine until updating to 2.22.0
                I hope somebody finds a solution for the screen rotation.
                Peter
                • E Offline
                  ecirpnaes @Peter
                  @Peter
                  I followed the instructions on this page.
                  https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi#enable-the-open-gl-driver-to-decrease-electrons-cpu-usage
                  They’re a little outdated because they deal with older versions also but the basic information is there.
                  Essentially, it seems that the Open GL driver is enabled by default now, so I had to:
                  sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
                  and added the following line.
                  @xrandr --output HDMI-1 --rotate right
                  • P Offline
                    Peter @ecirpnaes
                    @ecirpnaes thanks, will try it tomorrow.
                    Peter
                    • K Offline
                      Knight @sdetweil
                      @sdetweil Thanks, it worked after pi os update
