    Error on new installation
    7 Posts 2 Posters 869 Views 2 Watching
      requiemmg
      I just reinstalled my Pi from scratch (Raspbian Buster) and installed MM current version through @sdetweil 's installation script.
      Everything worked at once, MM started up on boot.
      Then I startet installing my modules, just git cloning them and doing npm install in the modules directories. No edit of config.js, I intend to use my old config.js.
      At some point I noticed that MM would not display - it is running, but electron throws an error:
      $ pm2 logs MagicMirror --lines=50
      [TAILING] Tailing last 50 lines for [MagicMirror] process (change the value with --lines option)
      /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
      0|MagicMir |
      0|MagicMir |
      0|MagicMir | > magicmirror@2.22.0 start
      0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      0|MagicMir |
      0|MagicMir |
      0|MagicMir |
      0|MagicMir |
      0|MagicMir |
      0|MagicMir |
      0|MagicMir |
      0|MagicMir | [05.01.2023 21:54.19.799] [LOG]   Starting MagicMirror: v2.22.0
      0|MagicMir | [05.01.2023 21:54.19.819] [LOG]   Loading config ...
      0|MagicMir | [05.01.2023 21:54.19.830] [LOG]   Loading module helpers ...
      0|MagicMir | [05.01.2023 21:54.19.835] [LOG]   No helper found for module: alert.
      0|MagicMir | [05.01.2023 21:54.19.866] [LOG]   Initializing new module helper ...
      0|MagicMir | [05.01.2023 21:54.19.867] [LOG]   Module helper loaded: updatenotification
      0|MagicMir | [05.01.2023 21:54.19.869] [LOG]   No helper found for module: clock.
      0|MagicMir | [05.01.2023 21:54.20.499] [LOG]   Initializing new module helper ...
      0|MagicMir | [05.01.2023 21:54.20.504] [LOG]   Module helper loaded: calendar
      0|MagicMir | [05.01.2023 21:54.20.508] [LOG]   No helper found for module: compliments.
      0|MagicMir | [05.01.2023 21:54.20.512] [LOG]   No helper found for module: weather.
      0|MagicMir | [05.01.2023 21:54.20.584] [LOG]   Initializing new module helper ...
      0|MagicMir | [05.01.2023 21:54.20.586] [LOG]   Module helper loaded: newsfeed
      0|MagicMir | [05.01.2023 21:54.20.587] [LOG]   All module helpers loaded.
      0|MagicMir | [05.01.2023 21:54.20.876] [LOG]   Starting server on port 8080 ...
      0|MagicMir | [05.01.2023 21:54.21.957] [LOG]   Server started ...
      0|MagicMir | [05.01.2023 21:54.21.964] [LOG]   Connecting socket for: updatenotification
      0|MagicMir | [05.01.2023 21:54.21.967] [LOG]   Starting module helper: updatenotification
      0|MagicMir | [05.01.2023 21:54.21.968] [LOG]   Connecting socket for: calendar
      0|MagicMir | [05.01.2023 21:54.21.970] [LOG]   Starting node helper for: calendar
      0|MagicMir | [05.01.2023 21:54.21.972] [LOG]   Connecting socket for: newsfeed
      0|MagicMir | [05.01.2023 21:54.21.976] [LOG]   Starting node helper for: newsfeed
      0|MagicMir | [05.01.2023 21:54.21.978] [LOG]   Sockets connected & modules started ...
      0|MagicMir | [05.01.2023 21:54.22.107] [LOG]   Launching application.
      0|MagicMir | [05.01.2023 21:54.29.651] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
      0|MagicMir | [05.01.2023 21:54.29.678] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      0|MagicMir | [05.01.2023 21:54.29.745] [INFO]  Checking git for module: default
      0|MagicMir | [05.01.2023 21:54.30.830] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
      0|MagicMir | [05.01.2023 21:54.31.214] [INFO]  Calendar-Fetcher: Broadcasting 15 events.
      0|MagicMir |
      0|MagicMir |
      /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
      0|MagicMir |     at f._load (node:electron/js2c/asar_bundle:2:13328)
      0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1035:19)
      0|MagicMir |     at require (node:internal/modules/cjs/helpers:102:18)
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:16:24)
      0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1141:14)
      0|MagicMir |     at Module._extensions..js (node:internal/modules/cjs/loader:1196:10)
      0|MagicMir | [2805:0105/214507.331437:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|MagicMir | [2825:0105/214507.549549:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
      0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      0|MagicMir | [3628:0105/215425.860928:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|MagicMir | [3670:0105/215426.220444:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
      0|MagicMir | [3641:0105/215426.273319:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      0|MagicMir | [05.01.2023 21:56.59.668] [ERROR] App threw an error during load
      0|MagicMir | [05.01.2023 21:56.59.690] [ERROR] Error: Cannot find module '/home/pi/MagicMirror/js/../modules/default/defaultmodules'
      0|MagicMir | Require stack:
      0|MagicMir | - /home/pi/MagicMirror/js/app.js
      0|MagicMir | - /home/pi/MagicMirror/js/electron.js
      0|MagicMir | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      0|MagicMir | -
      0|MagicMir |     at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)
      0|MagicMir |     at n._resolveFilename (node:electron/js2c/browser_init:2:109416)
      0|MagicMir |     at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
      0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:811:27)
      0|MagicMir | A JavaScript error occurred in the main process
      0|MagicMir | Uncaught Exception:
      0|MagicMir | Error: Cannot find module '/home/pi/MagicMirror/js/../modules/default/defaultmodules'
      0|MagicMir | -
      0|MagicMir | [1780:0105/215705.238610:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|MagicMir | [1804:0105/215706.349139:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|MagicMir | [1830:0105/215706.819295:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
      I renamed the MM directory and installed again. MM was running fine. Then I copied back the modules folder - and got this error back.
      Can anyone point out what is going wrong here?
        sdetweil @requiemmg
        @requiemmg it looks like something got erased
        when u are installing the other modules what do you do,?
          requiemmg @sdetweil
          @sdetweil I just go into the MagicMirror/modules folder, git clone https://repository.of.module, enter the modules directory and npm install. Thats it…
            requiemmg @requiemmg
            Well, redone everything, now working. No idea what went wrong in first place…
              sdetweil @requiemmg
              @requiemmg only npm install if the module has a package.json file, right?
              not always
                requiemmg @sdetweil
                @sdetweil Yes, only if indicated in the installation instructions to do so.
                  sdetweil @requiemmg
                  @requiemmg ok. just thinking of what would have caused the issue…
