    MM funktioniert nicht mehr nach Update
    13 Posts 2 Posters 2.8k Views 2 Watching
    • N Offline
      NickOne
      Habe heute ein MagicMirror Update ausgeführt und danach neu gestartet. Leider startet MM jetzt nicht mehr. Könnte mir da jemand weiter helfen? Danke schon mal.
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.14.12
      3 info using node@v10.24.1
      5 info lifecycle magicmirror@2.22.0~prestart: magicmirror@2.22.0
      6 info lifecycle magicmirror@2.22.0~start: magicmirror@2.22.0
      7 verbose lifecycle magicmirror@2.22.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.22.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.22.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.22.0~start: Args: [ '-c',
      10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
      11 info lifecycle magicmirror@2.22.0~start: Failed to exec start script
      12 verbose stack Error: magicmirror@2.22.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      12 verbose stack spawn ENOENT
      12 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
      12 verbose stack     at ChildProcess.emit (events.js:198:13)
      12 verbose stack     at maybeClose (internal/child_process.js:982:16)
      12 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      13 verbose pkgid magicmirror@2.22.0
      14 verbose cwd /home/pi/MagicMirror
      15 verbose Linux 4.19.66-v7+
      16 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      17 verbose node v10.24.1
      18 verbose npm  v6.14.12
      19 error code ELIFECYCLE
      20 error syscall spawn
      21 error file sh
      22 error errno ENOENT
      23 error magicmirror@2.22.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      23 error spawn ENOENT
      24 error Failed at the magicmirror@2.22.0 start script.
      24 error This is probably not a problem with npm. There is likely additional logging output above.
      25 verbose exit [ 1, true ]
        sdetweil @NickOne
        @NickOne node and npm are downlevel
        needs to be node 16 at least
        node@v10.24.1
        if u had used my install script it would have upgraded that for you.
        • N Offline
          NickOne
          Danke für die schnelle Antwort. “Node” hab ich jetzt geupdatet. Funktioniert leider aber immer noch nicht. Hab MM auch schon per Hand gestartet. Putty zeigt mir auch “online” an, aber auf dem Spiegel ist MM nicht zu sehen.
            sdetweil @NickOne
            @NickOne said in MM funktioniert nicht mehr nach Update:
            Nach dem Upgrade des Knotens müssen Sie npm install erneut ausführen.
            cd ~/MagicMirror
            rm -rf node_modules
            rm package-lock.json
            npm install
            • N Offline
              NickOne @sdetweil
              Habe mein Backup nochmals zurück gespielt. Da funktioniert auch noch alles. Habe danach das alles ausgeführt was Sie mir geschrieben hatten. Updates laufen durch, aber danach startet MM wieder nicht. Zumindestens nicht optisch. Wenn ich mir aber die Auslastung anschaue, sieht es schon so aus als wäre MM gestartet.
              0 verbose cli /usr/bin/node /usr/bin/npm
              1 info using npm@8.19.3
              2 info using node@v16.19.0
              3 timing npm:load:whichnode Completed in 1ms
              4 timing config:load:defaults Completed in 11ms
              5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 10ms
              6 timing config:load:builtin Completed in 12ms
              7 timing config:load:cli Completed in 11ms
              8 timing config:load:env Completed in 4ms
              9 timing config:load:file:/home/pi/MagicMirror/.npmrc Completed in 0ms
              10 timing config:load:project Completed in 9ms
              11 timing config:load:file:/home/pi/.npmrc Completed in 1ms
              12 timing config:load:user Completed in 2ms
              13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
              14 timing config:load:global Completed in 2ms
              15 timing config:load:validate Completed in 2ms
              16 timing config:load:credentials Completed in 8ms
              17 timing config:load:setEnvs Completed in 7ms
              18 timing config:load Completed in 82ms
              19 timing npm:load:configload Completed in 83ms
              20 timing npm:load:mkdirpcache Completed in 8ms
              21 timing npm:load:mkdirplogs Completed in 2ms
              22 verbose title npm start
              23 verbose argv "start"
              24 timing npm:load:setTitle Completed in 9ms
              25 timing config:load:flatten Completed in 20ms
              26 timing npm:load:display Completed in 27ms
              27 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs
              28 verbose logfile /home/pi/.npm/_logs/2023-01-15T14_41_15_770Z-debug-0.log
              29 timing npm:load:logFile Completed in 82ms
              30 timing npm:load:timers Completed in 0ms
              31 timing npm:load:configScope Completed in 1ms
              32 timing npm:load Completed in 221ms
              33 silly logfile start cleaning logs, removing 1 files
              34 silly logfile done cleaning log files
              35 timing command:run-script Completed in 913ms
              36 timing command:start Completed in 941ms
              37 verbose exit 127
              38 timing npm Completed in 1200ms
              39 verbose code 127
                sdetweil @NickOne
                @NickOne are you using pm2 to start?
                show output of
                pm2 logs --line=50
                • N Offline
                  NickOne @sdetweil
                  @sdetweil ja ich benutze den Autostart.
                  Aber MM von Hand starten bringt aber auch nichts. Was mir aber aufgefallen ist, das wenn ich MM über die Console starte, hinten in der Tabelle bei “Watching” disable ausgegeben wird.
                  │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                  │ 0 │ MagicMirror │ N/A │ 2.22.0 │ fork │ 8302 │ 0s │ 10 │ online │ 0% │ 2.5mb │ pi │ disabled
                    sdetweil @NickOne
                    Das Überwachen von Dateiänderungen wird nicht auf allen Plattformen unterstützt. (Wenn Sie config.js ändern und speichern, wird mm neu gestartet) …
                    Wie gesagt, ich muss die Ausgabe der Protokolle sehen.
                    Bitte
                    pm2 stop all
                    pm2 flush
                    pm2 start MagicMirror
                    20 Sekunden warten
                    pm2 logs  --lines=100 >somefile.txt
                    ctrl-c
                    und Beispiel somefile.txt
                    • N Offline
                      NickOne @sdetweil
                      Meinen Sie das hier?
                      0|MagicMirror | /home/pi/MagicMirror/node_modules/electron/dist/electron: symbol lookup error: /home/pi/MagicMirror/node_modules/electron/dist/electron: undefined symbol: gbm_bo_get_modifier
                      PM2 | App [MagicMirror:0] exited with code [127] via signal [SIGINT]
                      PM2 | App [MagicMirror:0] starting in -fork mode-
                      PM2 | TypeError [ERR_INVALID_ARG_TYPE]: The “data” argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received type number (16302)
                      PM2 | at Object.writeFileSync (node:fs:2195:5)
                      PM2 | at /usr/lib/node_modules/pm2/lib/God/ForkMode.js:258:12
                      PM2 | at wrapper (/usr/lib/node_modules/pm2/node_modules/async/internal/once.js:12:16)
                      PM2 | at next (/usr/lib/node_modules/pm2/node_modules/async/waterfall.js:96:20)
                      PM2 | at /usr/lib/node_modules/pm2/node_modules/async/internal/onlyOnce.js:12:16
                      PM2 | at WriteStream. (/usr/lib/node_modules/pm2/lib/Utility.js:186:13)
                      PM2 | at WriteStream.emit (node:events:513:28)
                      PM2 | at WriteStream.emit (node:domain:552:15)
                      PM2 | at node:internal/fs/streams:75:16
                      PM2 | at FSReqCallback.oncomplete (node:fs:192:23)
                      PM2 | App [MagicMirror:0] online
                        sdetweil @NickOne
                        thank you
                        one more command
                        lsb_release -a
                        but likely
                        https://github.com/MichMich/MagicMirror/issues/2989
