    MMM-ToDo Microsoft (missing ordering options)
    todotodolist
    5 Posts 3 Posters 827 Views 3 Watching
      Alfnie
      Hi, in using the ToDo integration with MM, I would like to order the Lists Alphabetically on Title.
      Also, there is an other option in the App as well: sort by Importance (Star).
      Also, in the App, one also can use Tags (#example). I would love to see these tags in color, like on this forum.
        sdetweil @Alfnie
        @Alfnie you should post to the modules GitHub issue page to engage the author.
          Alfnie @sdetweil
          Ok, I will do that anytime soon.
          Thanks for your reply, I am new and learning from it :-)
          • T Offline
            thobach
            I’m the author of https://github.com/thobach/MMM-MicrosoftToDo in case that’s the module you’re referring to ;)
            Hashtags are already color coded if you specify the “highlightTagColor” parameter (see https://github.com/thobach/MMM-MicrosoftToDo#installation).
            Sorting is possible with the parameter “orderBy”, unfortunately the API does not allow to order by title, which means it would need to be manually implemented on-top if that is a priority for you.
            I added though sorting by importance if you set the “orderBy” parameter to “importance”.
              Alfnie @thobach
              @thobach Thanks for your reply and actions!
              I have used the new parameter ‘importance’, but it has no effect yet. I restarted mm.
              Should I do some update of the module? Before I can use it’s properties?
              I already use the hashtags, really neat!
              Can you point me in a direction to ‘manually implement on-top ordering by title?’
              I can try something to code myself, if only I know where to start :-).
