    MM camera error - libmmal.so
    4 Posts 2 Posters 2.5k Views 2 Watching
      MarkV
      I’ve done a clean MM install that worked.
      After this i installed a module todo facial-recognition with the MMM-Face-Reco-DNN module.
      The problem doesn’t seem to be in the module but in MM and the picamera files escpecially the libmmal file. (https://forums.raspberrypi.com/viewtopic.php?t=324283)
      Also at first the module starts good and without problems. At the moment it tries to get a picture or video the error occures.
      The camera does work:
      cfc551e8-1b32-4a46-bd8e-01097e185e91-image.png 65cec8b3-f8f5-4f0a-8593-b704c2276004-image.png
      When i start the mirror this error occures when it tries to use the libmmal.so file:
      Some OS and version data:
      How can i get this to work?
      How can install the mmal libaries?
        sdetweil @MarkV
        @MarkV did u do a Google search on how to install the missing file? unrelated to magicmirror
          MarkV @sdetweil
          yeah i’ve search but didn’t find a sollution.
          Do you have any idea?
            sdetweil @MarkV
            @MarkV https://stackoverflow.com/questions/71787870/oserror-libmmal-so-cannot-open-shared-object-file-no-such-file-or-directory-w
            or
            https://forums.raspberrypi.com/viewtopic.php?t=51925
