    how can I change the volume?
    6 Posts 2 Posters 987 Views 2 Watching
      Axel51
      Hello,
      i did a fresh install of Bullseye OS and MM. But i can’t change the volume! Before it was enable on the taskbar . Any idea?
      thanks
        sdetweil @Axel51
        @Axel51 maybe
        https://forums.raspberrypi.com/viewtopic.php?t=324067
          Axel51 @sdetweil
          I have no speaker icon on the taskbar and no audio option with raspi-config command?
          Need help!
            sdetweil @Axel51
            @Axel51 I do not know
            did u change the video driver?
            A 2 Replies Last reply Reply Quote 0
              Axel51 @sdetweil
              i did the bullseye install and MM.
              and i changed nothing
              I can change the volume with the GoogleAssistant on the mirror only
                Axel51 @sdetweil
                As it was suggested, i added this line last in my /boot/cmdline.txt.
                snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_compat_alsa=0
                And now, i have the audio option in the raspi-config menu
