    Extreme basic question!
    3 Posts 2 Posters 989 Views 2 Watching
    • C Offline
      chris_d
      I’ve written my own module to display a set of family tasks which rotate each week.
      Once I’ve done some javascript to build a string of HTML, I display with.
              var element = document.createElement("div")
              element.className = "myContent
              element.innerHTML = output;
              return element
      I just want to format this element with an existing magic mirror class so that the text doesn’t look massive and out of place, say “title” for example. But I can’t work out how to actually achieve that.
        sdetweil @chris_d
        @chris_d in custom.css
         .module_name .classname {
           font-size:. ?????
        .module_name is your module name
        . classname is .myContent
        fix the missing " in your posted text
        note the dot in front. that means class
        no dot means element name (div, table. li, …)
        # means id
          @chris_d
          the string of things before the {
          is called the selector clause.
          this gives u the ability to ‘select’ the html elements you want to apply the styles to
          I use this cheat sheet to view the different choices
          https://www.w3schools.com/cssref/css_selectors.php
          the selector can be very complex
          here is one from my MMM-Config module
          .possibly-hidden-tab div:nth-child(2)  > div > div >div >ul >li:only-child >a[rel*="Item 1"] {
            display: none;
