    MMM-SunnyPortal not loading
    2 Posts 2 Posters 442 Views 2 Watching
      A Former User
      Re: MMM-SunnyPortal not loading
      I have the same Problem with the module, but no solution worked for me. PM2 log gave the following errors. Hopefully somebody can help me out, please.
      /home/pi/.pm2/logs/mm-error.log last 15 lines:
      0|mm | [04.02.2023 19:38.21.689] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|mm | [04.02.2023 19:38.21.691] [ERROR] Whoops! There was an uncaught exception…
      0|mm | [04.02.2023 19:38.21.692] [ERROR] ReferenceError: loggedIn is not defined
      0|mm | at Request._callback (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_helper.js:145:5)
      0|mm | at self.callback (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:185:22)
      0|mm | at Request.emit (node:events:513:28)
      0|mm | at Request. (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:1154:10)
      0|mm | at Gunzip. (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:1076:12)
      0|mm | at Object.onceWrapper (node:events:627:28)
      0|mm | at Gunzip.emit (node:events:513:28)
      0|mm | at endReadableNT (node:internal/streams/readable:1358:12)
      0|mm | at process.processTicksAndRejections (node:internal/process/task_queues:83:21)
      0|mm | [04.02.2023 19:38.21.693] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm | [04.02.2023 19:38.21.693] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      I would be very happy, if somebody could help me out. I’m just a amateur.
        sdetweil @Guest
        @Rennsemme I rejected your duplicate post. users w reputation less than 2 have every post reviewed. sometimes the reviewers are busy w other life things.
