    Duplicate mm.sh file
    2 Posts 2 Posters 931 Views 2 Watching
    • D
      dcwestra
      I have the mm.sh file in my root folder that most turtorials have you make.
      But I also found one in MagicMirror/installers/mm.sh. They both contain the same data.
      When I look at my HTOP, I see that both scripts are running. Should I delete one? Does having both run slow down my machine?
      For context, I’m running on a pi zero w2.
        sdetweil @dcwestra
        @dcwestra did u create one for the manual install (using the oe in MagicMirror folder) and then run my install script which create one (using installers/mm.sh)
        do pm2 status
