    MMM-OpenAI
    24 Posts 4 Posters 14.5k Views 4 Watching
      sdetweil @sdmydbr9
      @sdmydbr9 use a GoogleAssistant recipe
      see it’s recipies folder
        MMRIZE @sdmydbr9
        @sdmydbr9
        I have a few already, like MMM-Hotword or MMM-Clap, and some…
        Anyway new OpenAI’s Whisper looks so interesting, So I’ll make it as a STT module in a few days, hope so.
          sdmydbr9 @sdetweil
          @sdetweil I just meant it as a similar approach, I don’t actually want to implement the whole assistant module.
            sdmydbr9 @MMRIZE
            @MMRIZE I think the Hotword module is not Available anymore and the clap module, might work but it will not look as asthetic as activating with the hot word…
              Rags @MMRIZE
              @MMRIZE said in MMM-OpenAI:
              @Rags
              Speech example: Conjunction with MMM-GoogleTTS, now it can speak.
              https://youtu.be/daWuSfQc5Ns
              postProcessing: (helper, resp) => {
                let choice = resp.response?.choices[0]
                if (choice) helper.sendNotification('TTS_SAY', choice?.message?.content ?? choice?.text)
              I am getting a syntax error in these lines can you please check.
                Rags @Rags
                @MMRIZE
                It’s possible that the error is caused by using optional chaining in a JavaScript version that doesn’t support it.
                I modified the code as below, rewriting the code without using optional chaining.
                postProcessing: function(helper, resp) {
                let choice = resp.response ? resp.response.choices[0] : undefined;
                if (choice) {
                let message = choice.message ? choice.message.content.choice.text : undefined;
                if (message) {
                helper.sendNotification(‘TTS_SAY’, message);
                I am not getting any syntax error now. However, there is some issue with Google TTS (unrelated I think) , as it is sending a notification as TTS_Say_Error. Google TTS API hopefully is configured correctly as no errors are thrown up during starting MM. How should i go about resolving it.
                  MMRIZE @Rags
                  @Rags
                  Give me the front and backend log on error happens
                    MMRIZE @Rags
                    @Rags
                    TTS_SAY notification could have more complex payload like this.
                    .sendNotification("TTS_SAY", {
                      content: "Live long and prosper", //text to be spoken
                      //belows are optional
                      type: "text", // "text" or "ssml"
                      voiceName: "en-US-Standard-B",
                      languageCode: "en-US",
                      ssmlGender: "FEMALE",
                      callback: (error)=> {
                        console.log(error) // <= What you need.
                      Rags @Rags
                      @Rags said in MMM-OpenAI:
                      @MMRIZE @MMRIZE
                      Thanks for the update. Yes now it works fine. I am not getting "something is wrong’ messages, but prompts about the token lengths whenever they exceed.
                      Thanks. I hope there will be voice integration soon.
                      So once again some issue has cropped up. The Openai integration with Telegrambot was working fine up to now. However, now the /chatai messages are not getting displayed on the MM whereas they are getting displayed on the Telegrambot app on the phone. The /txtai and /imgai have no issues. Please help in getting it to work again.
                      R M 2 Replies Last reply Reply Quote 0
                        Rags @Rags
                        @MMRIZE @MMRIZE
                        Can the developer please look into the issue described above. Thanks
                        • 2 / 3
