    How hard would it be to make the MM Calendar interactable?
    3 Posts 2 Posters 1.2k Views 2 Watching
    • W Offline
      wfsaxton
      I’d like to make an MM with touch screen with a calendar that I could interact with, similar to a regular calendar app (add event, modify event, etc).
      How difficult would this be to implement in MM?
        sdetweil @wfsaxton
        @wfsaxton the apps in mm for calendar just read the data provided by a real calendar system.
        they don’t provide any way to modify any calendar. you would have to use whatever API the calendar provider provides.
        adding all the forms. fields. etc for data entry/edit shouldn’t be too bad integrating with the default cal module might be too much tho. you might be able to have an invisible touch section on top of the cal module to enable the kind of function you mentioned
        • W Offline
          wfsaxton @sdetweil
          @sdetweil That’s what I thought. Thanks for the reply.
