    Standard module Calendar hangs on events
    30 Posts 2 Posters 11.8k Views 2 Watching
      sdetweil @Laz
      @Laz the EAI_AGAIN error is a networking error…
      the library we use does the work , nothing in our code…
      the code needs to get the IP address of the server to connect
      it looks up the name to get the address
      this failed… name not found
      thats all we got… “we can’t look this up now, please try again”
      no idea where in the network from the pi outward what error caused the failure
      L 5 Replies Last reply Reply Quote 0
      • L Offline
        Laz @sdetweil
        @sdetweil I will try to make ping permanent to these addresses (if Google allows ping) or contact the Internet provider.
        • L Offline
          Laz @sdetweil
          @sdetweil Good afternoon
          Here is another very strange situation. Now I see that there is no calendar update. View the error log file, but there are no errors. But the date of the error file is April 8th! Today is April 9th.
          I’ll give you screenshots and try to overload the mirror.
          [07.04.2023 10:54.57.922] [ERROR] Newsfeed Error. Could not fetch newsfeed:  http://tyumen-news.net/rss/news Error: Bad Gateway
              at NodeHelper.checkFetchStatus (/home/vova/MagicMirror/js/node_helper.js:120:9)
              at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
          [07.04.2023 14:12.12.283] [ERROR] Newsfeed Error. Could not fetch newsfeed:  https://www.ixbt.com/export/utf8/hardnews.rss Error: Bad Gateway
          [08.04.2023 05:09.10.408] [ERROR] Newsfeed Error. Could not fetch newsfeed:  https://www.ixbt.com/export/utf8/hardnews.rss Error: Gateway Time-out
          [08.04.2023 05:14.10.782] [ERROR] Newsfeed Error. Could not fetch newsfeed:  https://www.ixbt.com/export/utf8/hardnews.rss Error: Bad Gateway
          /home/vova/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
          MESA-LOADER: failed to retrieve device information
          MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: невозможно открыть разделяемый объектный файл: Отказано в доступе (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
          failed to load driver: kms_swrast
          MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: невозможно открыть разделяемый объектный файл: Отказано в доступе (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
          failed to load swrast driver
          [12318:0408/113452.405608:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
          X connection to :0 broken (explicit kill or server shutdown).
          It can be seen that on the 8th at 18-00 the second calendar stopped being polled.
          And at 21-15, the first calendar stopped being interviewed.
          And there is still no poll.
          I’m pinging Google right now, ping is great…
          • L Offline
            Laz @sdetweil
            @sdetweil Before rebooting.
            • L Offline
              Laz @sdetweil
              @sdetweil After the reboot. Both calendars were immediately updated.
              And the error log file was immediately updated!
              But I don’t see any network-related calendar errors in it… (
              [1374:0408/120432.325630:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
              [1374:0408/120432.326975:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
              [1374:0408/120435.597191:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
              [6024:0409/124326.890535:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
              • L Offline
                Laz @sdetweil
                @sdetweil Perhaps the error is not related to the availability of Google servers?
                  sdetweil @Laz
                  @Laz the 1st error
                  internal server error
                  is Google’s
                  the EAI_AGAIN
                  is not Google’s,
                  your request never made it there as the underlying code couldn’t get the IP address to use.
                  this is a network problem, somewhere
                  • L Offline
                    Laz @sdetweil
                    @sdetweil I sent some messages today. But only the latter got here. There are a little oddities there. Have you read them?))
                    Today, too, calendars have hung, but I have not seen any network errors.
                      sdetweil @Laz
                      @Laz no messages pending
                      I see the links in the posts below but not in the pending list. weird… sorry for the delay
                      these errors are outside of MagicMirror control.some may be recoverable, some may not. we don’t control the network stack
                      • L Offline
                        Laz @sdetweil
                        @sdetweil After tomorrow I will try to repeat briefly…))
