    Every time I run an update, something breaks. This time is no exception
    5 Posts 2 Posters 2.0k Views 2 Watching
      redink
      I don’t know what I am doing wrong, but every time I try to make any kinds of changes, I end up breaking the mirror.
      I would be greatful if someone could help me get the mirror running again
      Here are some logs
      pi@raspberrypi:~/MagicMirror $ cat /home/pi/.npm/_logs/2023-04-02T14_45_07_527Z-debug.log
      1 verbose cli [ '/usr/bin/node', '/usr/local/bin/npm', 'start' ]
      2 info using npm@6.14.4
      3 info using node@v10.15.2
      5 info lifecycle magicmirror@2.22.0~prestart: magicmirror@2.22.0
      6 info lifecycle magicmirror@2.22.0~start: magicmirror@2.22.0
      7 verbose lifecycle magicmirror@2.22.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.22.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.22.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.22.0~start: Args: [ '-c',
      10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
      11 silly lifecycle magicmirror@2.22.0~start: Returned: code: 1  signal: null
      12 info lifecycle magicmirror@2.22.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.22.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      13 verbose stack Exit status 1
      13 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13 verbose stack     at EventEmitter.emit (events.js:189:13)
      13 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:189:13)
      13 verbose stack     at maybeClose (internal/child_process.js:970:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      14 verbose pkgid magicmirror@2.22.0
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 4.19.97-v7+
      17 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "start"
      18 verbose node v10.15.2
      19 verbose npm  v6.14.4
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.22.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.22.0 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      pi@raspberrypi:~/MagicMirror $ tail -f /home/pi/.pm2/logs/MagicMirror-error.log
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.22.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.22.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2023-04-02T14_44_34_392Z-debug.log
      /home/pi/MagicMirror/node_modules/electron/index.js:17
          throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again');
      Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
          at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:17:11)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/index.js:21:18)
          at Module._compile (internal/modules/cjs/loader.js:689:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:700:10)
          at Module.load (internal/modules/cjs/loader.js:599:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:538:12)
          at Function.Module._load (internal/modules/cjs/loader.js:530:3)
          at Module.require (internal/modules/cjs/loader.js:637:17)
          at require (internal/modules/cjs/helpers.js:22:18)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/cli.js:3:18)
        redink @sdetweil
        @sdetweil What I kept trying to do is get node and npm updated, but I royally screwed things up where nothing is working anymore. I can’t use the PM2 command to start and stop things or see the status. So, I just nuked the SD card and am starting from scratch. I will use your scripts.
          sdetweil @redink
          @redink said in Every time I run an update, something breaks. This time is no exception:
          sadly it happens
          delete the folder as suggested and do
          cd ~/MagicMirror
          npm install electron@22.0.0
          how did u upgrade? manual git pull or my upgrade script?
          what hardware are you on?
          uname -a
          and lsb_release -a
          will give us info
          little look at your output again
          you are way downlevel…
          if u had used my script, I would have upgraded node and npm for you .
          see https://github.com/sdetweil/MagicMirror_scripts
          I try to help avoid the fatal upgrades that you experience
          note
          latest MM won’t run on raspi os stretch or earlier, so one has to upgrade sd card too.
            redink @sdetweil
            @sdetweil, i just kinda kept trying random things, including your script and I think I made things worse. I did try to update node and npm, but something is really out of whack.
            The error I keep seeing over and over again is
            npm WARN npm npm does not support Node.js v10.24.0
            npm WARN npm You should probably upgrade to a newer version of node as we
            npm WARN npm can't make any promises that npm will work with this version.
            when I run “node -v”, i see v19.8.1, so I have no idea where 10.24.0 is coming from. I am close to just nuking my pi and starting from scratch.
              sdetweil @redink
              @redink what are you doing when u see those messages?
                redink @sdetweil
