    Calendar and Weather modules (core/default) issues/questions
    2 Posts 2 Posters 1.8k Views 2 Watching
    • C
      ChampaignCowboy
      1. Weather only ever shows 5 days plus today, even if I configure for 14 days.
      2. Calendar never shows the start times of my events. Is there a config I’m missing?
      3. Is there a way to set a background “shade” for modules? I’ve got a background image running and it would be great if all my text blocks actually had a slight “grey” (mostly transparent) background to make the text more readable.
      4. is this the right place to post about the built in modules?
        sdetweil @ChampaignCowboy
        @ChampaignCowboy
        1. some providers only give 5 days for free… (used to be everyone gave out free data)
        2. calendar ONLY shows start, unless
        showEnd: true
        is set
        1. module background is usually transparent.
          well… you can set something in css/custom.css
        .module-content {
           background-color: gray;
        but… the module space has a border, AND modules can set their own backgrounds,
        SO, its not a simple change…
        1. yes, unless there is a bug, then open an issue in the MM github repo
