    MMM-OpenWeatherForecast No API Key
    5 Posts 2 Posters 1.5k Views 2 Watching
      jclewis
      Hello all,
      Just installed the MMM-OpenWeatherForecast module. I created an account with open weather and I am using the “One Call API 3.0.” I tested the default api key using their example: https://api.openweathermap.org/data/3.0/onecall?lat={lat}&lon={lon}&exclude={part}&appid={API key}. I checked the usage and it registered. However when I start the MM it comes back with ERROR ** No API key configured. Get an API key at https://openweathermap.org/api/one-call-api. I also created a new API key and tried that but with the same error.
      Has anyone run into this? Whats the fix? Any information would be greatly appreciated. Thank you.
        sdetweil @jclewis
        @jclewis please show the module config in config.js
        you can xxx out the apikey value…
        all module specific parms go INSIDE the AND the system i case sensitive, so
        apikey and apiKey are different
          module:"modulename",
           config:{
        ...         <---- here
        section
        read the two topics in my signature… I didn’t write them,
          jclewis @sdetweil
          			module: "MMM-OpenWeatherMapForecast",
          			header: "House Weather",
          				apiKey: "###",
          				latitude: "###",
          				longitude: "###",
          				iconset: "6oa",
          				concise: "false",
          				forecastLayout: "table"
            sdetweil @jclewis
            @jclewis said in MMM-OpenWeatherForecast No API Key:
            > apiKey: "###",
            yep
            doc says
             apikey:
            as I said, case sensitive
            also, for future, posting of code or config , use the code wrapper
            post the text
            select the text you just posted
            and hit the button above the editor that looks like </>
              jclewis @sdetweil
              Thanks for the catch. I appreciate it and the tips for future post. First time posting here.
