    MMM-Trello - No checklist
    5 Posts 2 Posters 1.1k Views 2 Watching
    • K Offline
      kasperinline
      Hello everybody
      When starting MargicMirror I don’t get any checklist in the MMM-Trello module - It just keep loading and loading
      DSC-0869)
      What I have tried:
      Different regions in MagicMirror
      Sudo update/upgrade
      Reboots
      2 Different API and Tokens
      Anybody have a clue on whats going on?
        sdetweil @kasperinline
        @kasperinline look in the output of where you do npm start
        to see any errors…
        • K Offline
          kasperinline @sdetweil
          @sdetweil said in MMM-Trello - No checklist:
          to see any errors…
          This is the only errors :
          /home/kasper/.pm2/logs/MagicMirror-error.log last 15 lines:
          0|MagicMir | /home/kasper/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
          0|MagicMir | MESA-LOADER: failed to retrieve device information
          0|MagicMir | MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
          0|MagicMir | failed to load driver: kms_swrast
          0|MagicMir | MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
          0|MagicMir | failed to load swrast driver
          Anything related to the module?
            @kasperinline not enough info
            do this
            open a terminal window of use ssh
            ctrl-m on MagicMirror screen to minimize to desktop
            pm2 stop all
            cd ~/MagicMirror
            npm start >somefile.txt 2>&1
            then when MagicMirror comes up , wait a little, then ctrl-m to minimize abd ctrl-c to stop mm
            then look at sometime.txt, it will have all the messages from this run
            to resume mm using pm2,
            pm2 status
            and use the name or number
            pm2 start ??
            where ?? is the name or number
            • K Offline
              kasperinline
              Thank you for your time and answer
              The list works today, and I dont know why :confused_face:
              The only thing I did, was to turn on the Raspberry
