    Bullseye Display timeout
    6 Posts 2 Posters 2.8k Views 3 Watching
      alex2
      I have been running MM for sometime on a PI B3+. Recently I was doing updates and it would no longer work, which I believe was due to the OS I was running on the PI. I ended up doing a backup, upgrading to Bullseye, and then re-rolling the mirror. Everything works good, with the exception of the display timeout settings. No matter what I do, it doesn’t appear I can get the display to stay on perpetually. It always times out after some time. The display doesn’t go off as I can see the backlighting still on when it’s night, but the signal times out. I can prompt it to come back online, but want it to just stay on at all times. any thoughts?
        sdetweil @alex2
        @alex2 use the script that I provide (as part of MM install)
        https://github.com/sdetweil/MagicMirror_scripts#turn-off-screen-saver-and-setup-pm2-to-autostart-mm-on-boot
        for all the scripts see
        A 2 Replies Last reply Reply Quote 0
          alex2 @sdetweil
          Just ran the script. Will advise if it works. Thank you.
            alex2 @sdetweil
            This seems to have worked. Thank you so much!
              alex2
              Well I spoke too soon. After running your script it stayed on longer than 10 minutes, but after 1-2 hours, it went black yet again.
                alex2 @alex2
                After a few other reboots, this does seem to be working now.
