    MMM-Carousel w/ Slide Navigation changing page alone
    4 Posts 3 Posters 915 Views 3 Watching
      JonnyAG38
      Hi guys, my magic mirror is switching between pages alone, here is my config.js:
          module: 'MMM-Carousel',
                  position: 'bottom_bar',  // Only required to show navigation
      				transitionInterval: 10000,
                      showPageIndicators: true,
                      showPageControls: true,
                      ignoreModules: ["clock", "MMM-GoogleCalendar", "MMM-page-indicator"], //FIXOS
                      mode: 'slides',
                       slides: [
                          ["newsfeed","weather","MMM-Spotify","MMM-SmartTouch"],
                          ["MMM-GoogleTasks","MMM-Formula1"]
      i used this fork https://github.com/KristjanESPERANTO/MMM-Carousel/
      S V 2 Replies Last reply Reply Quote 0
        sdetweil @JonnyAG38
        @JonnyAG38 yes, you said 10000 milliseconds, then change to next. but that is carousel’s primary function, to auto rotate
        MMM-pages does not auto rotate. it can
        • V Offline
          vandyck @JonnyAG38
          @JonnyAG38
          TransitionInterval:
          The number of milliseconds to display each module for.
          This value is OPTIONAL
          Possible values: Any valid int, passing 0 with mode:“slides” will disable the timer for manual navigation.
          Default value: 10000
          You have to use Transistiontimeout, I think.
            sdetweil @vandyck
            @vandyck passing 0 in slides mode will disable…
            yes, he has it set to 10000, not 0
