    Install Magic Mirror on Home Assistant
    3 Posts 2 Posters 1.7k Views 2 Watching
    • C
      Coatesy89
      I have a pi zero 2 which has a small 7" screen attached which I use to show magic mirror through a browser, as I could not get it to install correctly on the pi zero 2. I was previously hosting magic mirror on a pi 4 8gb, which was also used as a desktop pc running Pi OS.
      I have since decided to repurpose the pi4 and have installed Home Assistant on it.
      Is it possible to install magic mirror onto the pi now that is running the home assistant OS, allowing me to access magic mirror through a browser in the same way I used to.
      Alternatively, any suggestions on how to install magic mirror on a pi zero 2?
      Cheers
        sdetweil @Coatesy89
        @Coatesy89 I don’t know the answer to the mm on home assistant os. but installing on pi02 is easy…
        flash the SD card w the latest bullseye and run my install script.
        C 1 Reply Last reply
        • C
          Coatesy89 @sdetweil
          @sdetweil your script worked, thank you.
          For now I will keep the 4b only running home assistant.
