    MMM-DHT-Sensor stopped working
    20 Posts 4 Posters 5.5k Views 4 Watching
      sdetweil @ankonaskiff17
      @ankonaskiff17 cool. never read that part of the doc.
      also says you can’t install over ssh, but it’s the ONLY way I install mm., ever
      • ankonaskiff17A Online
        ankonaskiff17
        I can build my digital picture frame without going though a bunch of gyrations and that was my goal so I’m content. 3 - 4 days ago that looked grim.
        Now to look into your comment about a server for all my pictures and see what that requires.
        Stuff I’m likely ignorant of at this moment I’m sure.
          @ankonaskiff17 i had a spare machine, installed linux 10 years ago… have a 5tb external drive with the pics and and a lot of other stuff…
          share via samba (windows file sharing)
          and mount that on the pi (line in /etc/fstab)
          ends up in /media/{username}/…configed_name
          then u can link (ln) to map in to a folder some other place with a new name…
            Dracarys @ankonaskiff17
            @ankonaskiff17 Yes sudo apt-get update and sudo apt-get upgrade. Other modules work again just the DHT wont work :(
              Dracarys
              Fixed it. Updating the magic mirror itself did the trick.
              ankonaskiff17A J 3 Replies Last reply Reply Quote 0
                ankonaskiff17 @Dracarys
                @Dracarys As in updating to 2.24.0?
                Those are the best kind.
                  @Dracarys I want to dig in to sensor projects myself. I looked at that DHT sensor and I think it is using SPI so maybe other sensors using same interface might be amenable to using module as a building block.
                    Jonae @Dracarys
                    @Dracarys mine is still broken, updated MM to version 2.24.0 and still not working. Any solution?
                    ankonaskiff17A 1 Reply Last reply Reply Quote 0
                      ankonaskiff17 @Jonae
                      @Jonae How many wires on sensor? 3 or 4? There are some DHT sensors with 4, some with 3.
                      If it is 4, and/or you know it is I2C ,try running ```sudo i2cdetect -y 1’‘’ .
                      Should spit you out an address 38.
                      If not I have a 3 wire sensor I can hook up and run through setup. My 3 wire sensor and DHT supposed to be about twins.
                        Jonae @ankonaskiff17
                        @ankonaskiff17
                        I have a 4 wire sensor, eunning sudo i2cdetect -y 1 i am getting an error thet could not open file. Anny sugestions?
