    Max Entry issue with Default Calendar Module
    5 Posts 2 Posters 1.0k Views 2 Watching
    • V Offline
      Vanstone
      I am currently using the default calendar module with only one google calendar. I would like to have more than 10 entries in the event list. I assumed that using maximumEntries would do the trick…but upon some digging and debugging the code I have found that it constrains the list to the default value set in calendar.js regardless of my maximumEntries config value (even though documentation says I can have up to 100).
      In debugging I found that my event array comes back from Google with 999 entries. Then the event list is sliced down to 18 (since this is my config value) and then later it is further sliced to 10 (the default value set on line 12 of calendar.js) – here is the code line that takes my event array from 18 to 10 :
      return events.slice(0, this.config.maximumEntries); (calendar.js 661)
      I may be missing something but this seems like a bug and wanted to know if I am missing some developer intention before reporting it as such (on a side note it seems that the fade property also cannot be set via the config) - likely whatever is setting this.config is not pulling in the config file values but leaving them as set in the defaults section.
      My Config Section:
      module: “calendar”,
      header: “Family Events”,
      position: “middle_center”,
      { maximumEntries: 18,
      symbol: “calendar-check”,
      url: "https://calendar.google.com/calendar/i
      **** Using MM v2.24.0 ***
        sdetweil @Vanstone
        @Vanstone maxinumEntries is not calendar specific. move it above the calendars:[
        line
        • V Offline
          Vanstone
          Thanks for responding. I changed the position to be at the module level but the change had no affect. If I have the MaximumEntries in the specific calendar scope it does work if I constrain the MaximumEntries to less than 10 (say 3 for example). If I constrain it to 3 with the MaximumEntries at the module level it does not affect the number of entries. So I am still in the same boat.
            sdetweil @Vanstone
            @Vanstone show me the new config, x out the url
            • V Offline
              Vanstone
              			header: "Family Events",
              			position: "middle_center",
              			maximumEntries: 3, // <---- down one line after config:{, before calendars:[
              						symbol: "calendar-check",
              						url: "https://calendar.google.com/calendar/ical/orfr24if0dittkie6ml35f0bes%40group.calendar.google.com/private-XXXXXXXXXXXX/basic.ics"
