    MMM-PublicTransportHafas does not update departure times after startup
    7 Posts 5 Posters 3.1k Views 5 Watching
    • H Offline
      Hinge
      i have installed the latest MM² software on a Raspberry Pi3. Default runs everything fine (weather, calendar and so on).
      Now i tried the 3rd-Party Module MMM-PublicTransportHafas (https://github.com/raywo/MMM-PublicTransportHafas).
      If i start the MM² (pm2 restart MagicMirror) the latest informations about the departures are shown. But then nothing more happens. If i start the MM² at 12 o’clock, the departes stay for example at 12:08. And stay and stay. In the ‘config.js’ of the MM² i configered the updatesEvery on 180 (seconds).
      The Weathermodule and the calendar-module are fine and always up to date.
      Is there something if forgot?
      Thanks,
      Hinge
      S B 2 Replies Last reply Reply Quote 0
        sdetweil @Hinge
        @Hinge maybe the module has a bug?
        thgmirrorT 1 Reply Last reply Reply Quote 0
        • thgmirrorT Offline
          thgmirror @sdetweil
          @Hinge for me it runs perfect.
            boehmch @Hinge
            @Hinge
            i use this https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas . The Module works fine and stable
            • H Offline
              Hinge
              My Error :man_facepalming:
              At the end of the description of the hafas-modul stands:
              • The update will also be stopped by the use of a PIR sensor using the module MMM-PIR-Sensor (that sends the notification ‘USER_PRESENCE’).
              After comment the part of the MMM-Pir in the config.js file out, everything is fine.
              THX
              • KristjanESPERANTOK Offline
                KristjanESPERANTO Module Developer @Hinge
                @Hinge Can you please describe in more detail what you commented out?
                • H Offline
                  Hinge @KristjanESPERANTO
                  @KristjanESPERANTO
                  the entire MMM-Pir modul.
                  Like
                                          module: 'MMM-Pir',
                                          position: 'bottom_left',
                                                  debug: false,
                                                  delay: 1 * 30 * 1000,
                                                  turnOffDisplay: true,
                                                  mode: 1,
                                                  ecoMode: true,
                                                  displayCounter: true,
                                                  displayBar: true,
                                                  displayStyle: "Text",
                                                  displayLastPresence: true,
                                                  lastPresenceTimeFormat: "LL H:mm",
                                                  mode6_gpio: 20,
                                                  mode6_clearGpioValue: true,
                                                  pir_gpio: 21,
                                                  pir_reverseValue: false
                  The display runs now 24/7, but i got my departures ;-)
                  I will take a look at the problem with “user_presence” later.
