npm install
5 Posts 2 Posters 720 Views 2 Watching
  • P Offline
    pat59
    hello I can’t install npm install I still have this error message.
    patrick@raspberrypi:~/MagicMirror $ npm install
    npm WARN npm npm does not support Node.js v20.6.1
    npm WARN npm You should probably upgrade to a newer version of node as we
    npm WARN npm can’t make any promises that npm will work with this version.
    npm WARN npm Supported releases of Node.js are the latest release of 6, 8, 9, 10, 11, 12.
    npm WARN npm You can find the latest version at https://nodejs.org/
    npm ERR! cb.apply is not a function
    npm ERR! /home/patrick/.npm/_logs/2023-09-18T06_33_42_489Z-debug.log
    S 1 Reply Last reply Sep 18, 2023, 11:49 AM Reply Quote 0
    • S Online
      sdetweil @pat59
      @pat59 how did you get in the situation what were you doing?
      there is a link in the messages that says how to upgrade the latest version
      you need to upgrade NPM as it and node of now gotten out of sync
      • P Offline
        pat59
        Hello thank you
        I actually clicked on the link for the update nothing to change I will see thank you
        S 1 Reply Last reply Sep 18, 2023, 2:43 PM Reply Quote 0
        • S Online
          sdetweil @pat59
          @pat59 start over and use my install script …
          • P Offline
            pat59
            Thank you so much Sdetweil
