    RuuviTag sensor connectivity
    2 Posts 2 Posters 570 Views 2 Watching
    • B
      blackbull
      Does anyone know a working module to connect RuuviTag sensors into MagicMirror, with the latest Ruuvi firmwares installed in the sensors? https://ruuvi.com/
      Or interest into developing one, or refining something excisting?
      To my knowledge, there has been some module to support RuuviTags with the older firmwares, but this is was not supporting the new firmware for some reason.
      With kind regards,
      SP / blackbull
        sdetweil @blackbull
        @blackbull I am not aware of a module, but they have a forum to discuss their sensors which they say are open source
        https://f.ruuvi.com/
        the sensors send data over Bluetooth, so you will have to use a script in the background using Bluetoothctl and hcitool.
        the script will run thru the node_helper, and then send the values up to the web side of the module for display
