    MMM-PIR-Sensor not work after v2.25
    11 Posts 2 Posters 6.4k Views 3 Watching
    • J
      JoeFranz
      Thanks to the great help from @sdetweil, my MagicMirror is now running again after the last update. I was able to fix problems with two modules myself. I just can’t get the MMM PIR sensor module to work. I tried this, and so far it has always worked after an update. Unfortunately not now…
      cd ~/MagicMirror/modules
      cd MMM PIR sensor
      npm i magicmirror rebuild
      ./node_modules/.bin/MagicMirror-rebuild
      Anyone an idea?
      Greetings Jörg
      S J 2 Replies Last reply Reply Quote 0
      • J
        JoeFranz @sdetweil
        @sdetweil Ok, I managed it :-)
        Now everything is working again as it was before the update, thank you again :-)
          sdetweil @JoeFranz
          @JoeFranz if you ran my upgrade script it should fix that
          you MUST install electron-rebuild in the base node_modules and execute it from there while in the module folder.
          see the postinstall script in my fixed fork
          https://github.com/sdetweil/MMM-PIR-Sensor
          • J
            JoeFranz @JoeFranz
            @sdetweil after npm install:
            Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall
            node_modules/.bin/electron-rebuild -e …/…/node_modules/electron
            sh: 1: node_modules/.bin/electron-rebuild: not found
            npm ERR! code 127
            npm ERR! path /home/pi/MagicMirror/modules/MMM-PIR-Sensor
            npm ERR! command failed
            npm ERR! command sh -c node_modules/.bin/electron-rebuild -e …/…/node_modules/electron
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-03T12_42_43_352Z-debug-0.log
              sdetweil @JoeFranz
              @JoeFranz did you run this while the command prompt is in the module folder?
              • J
                JoeFranz @sdetweil
                @sdetweil yes
                  sdetweil @JoeFranz
                  @JoeFranz I am confused
                  (base) sam@sams:~/MagicMirror/modules$ cd MMM-PIR-Sensor/
                  (base) sam@sams:~/MagicMirror/modules/MMM-PIR-Sensor$ npm install
                  > ./postinstall
                  /home/sam/MagicMirror/modules/MMM-PIR-Sensor
                  ⠹ Building module: epoll, Completed: 0make: Entering directory '/home/sam/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
                    CXX(target) Release/obj.target/epoll/src/epoll.o
                  ⠦ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                    COPY Release/epoll.node
                  make: Leaving directory '/home/sam/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
                  ✔ Rebuild Complete
                  added 6 packages, and audited 7 packages in 13s
                  found 0 vulnerabilities
                  and
                  (base) sam@sams:~/MagicMirror/modules/MMM-PIR-Sensor$ ./postinstall
                  ✔ Rebuild Complete
                  this is HIS BROKEN postinstall which tries to execute it from the MODULE node_modules… which WILL NOT WORK anymore
                  I have a script which checks if it is installed in the base, if not installs it and THEN executes it FROM the base (note the leading … to point back to the base… )
                  ../../node_modules/.bin/electron-rebuild
                  do this
                  cd ~/MagicMirror/modules/MMM-PIR_Sensor
                  curl -sL https://raw.githubusercontent.com/sdetweil/MMM-PIR-Sensor/master/postinstall >postinstall
                  chmod +x postinstall
                  ./postinstall
                  OR rename the existing module folder to some other name
                  git clone and npm install mine…
                  no code changes… just this packaging for rebuild
                  • J
                    JoeFranz @sdetweil
                    @sdetweil I renamed the folder and reinstalled the module, this is the result:
                    pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install
                    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                    npm WARN deprecated electron-rebuild@1.11.0: Please use @electron/rebuild moving forward.  There is no API change, just a package name change
                    npm ERR! code 7
                    npm ERR! path /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                    npm ERR! command sh -c node-gyp rebuild
                    npm ERR! gyp info it worked if it ends with ok
                    npm ERR! gyp info using node-gyp@6.1.0
                    npm ERR! gyp info using node@20.8.0 | linux | arm
                    npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
                    npm ERR! gyp ERR! UNCAUGHT EXCEPTION
                    npm ERR! gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
                    npm ERR! gyp ERR! stack     at createConfigFile (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/lib/configure.js:118:21)
                    npm ERR! gyp ERR! stack     at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/lib/configure.js:85:9
                    npm ERR! gyp ERR! stack     at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/mkdirp/index.js:30:20
                    npm ERR! gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:189:23)
                    npm ERR! gyp ERR! System Linux 6.1.21-v7+
                    npm ERR! gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/.bin/node-gyp" "rebuild"
                    npm ERR! gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                    npm ERR! gyp ERR! node -v v20.8.0
                    npm ERR! gyp ERR! node-gyp -v v6.1.0
                    npm ERR! gyp ERR! This is a bug in `node-gyp`.
                    npm ERR! gyp ERR! Try to update node-gyp and file an Issue if it does not help:
                    npm ERR! gyp ERR!     <https://github.com/nodejs/node-gyp/issues>
                    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-03T13_57_09_313Z-debug-0.log
                      sdetweil @JoeFranz
                      @JoeFranz said in MMM-PIR-Sensor not work after v2.25:
                      “/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/.bin/node-gyp” “rebuild”
                      no… still using the wrong MMM-PIR-Sensor distro
                      delete the one you have and do
                      git clone
                      https://github.com/sdetweil/MMM-PIR-Sensor.git
                      cd MMM-PIR-Sensor
                      npm install
                      • J
                        JoeFranz @sdetweil
                        @sdetweil ok, that worked now, my mistake :-(
                        I also made updates for the pi, unfortunately I now also have the latest firmware version: 82f3750a65fadae9a38077e3c2e217ad158c8d54 from March 2023. I’ve had that before, so the monitor on the pi doesn’t go into standby. I now need to downgrade the firmware to version 5.10 (b976c54917e240630c05a9b383010f1492bc61b4). When I try with “sudo rpi-update b976c54917e240630c05a9b383010f1492bc61b4” it says that the firmware is already up to date.
                          sdetweil @JoeFranz
                          @JoeFranz sorry on the firmware, don’t know how to downgrade firmware
                          • J
                            JoeFranz @sdetweil
