    MMM-PIR-Sensor not work after v2.25
    11 Posts 2 Posters 5.5k Views 3 Watching
      sdetweil @JoeFranz
      @JoeFranz did you run this while the command prompt is in the module folder?
        JoeFranz @sdetweil
        @sdetweil yes
          sdetweil @JoeFranz
          @JoeFranz I am confused
          (base) sam@sams:~/MagicMirror/modules$ cd MMM-PIR-Sensor/
          (base) sam@sams:~/MagicMirror/modules/MMM-PIR-Sensor$ npm install
          > Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall
          > ./postinstall
          /home/sam/MagicMirror/modules/MMM-PIR-Sensor
          ⠹ Building module: epoll, Completed: 0make: Entering directory '/home/sam/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
            CXX(target) Release/obj.target/epoll/src/epoll.o
          ⠦ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
            COPY Release/epoll.node
          make: Leaving directory '/home/sam/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
          ✔ Rebuild Complete
          added 6 packages, and audited 7 packages in 13s
          found 0 vulnerabilities
          and
          (base) sam@sams:~/MagicMirror/modules/MMM-PIR-Sensor$ ./postinstall
          ✔ Rebuild Complete
          node_modules/.bin/electron-rebuild -e …/…/node_modules/electron
          this is HIS BROKEN postinstall which tries to execute it from the MODULE node_modules… which WILL NOT WORK anymore
          I have a script which checks if it is installed in the base, if not installs it and THEN executes it FROM the base (note the leading … to point back to the base… )
          ../../node_modules/.bin/electron-rebuild
          do this
          cd ~/MagicMirror/modules/MMM-PIR_Sensor
          curl -sL https://raw.githubusercontent.com/sdetweil/MMM-PIR-Sensor/master/postinstall >postinstall
          chmod +x postinstall
          ./postinstall
          OR rename the existing module folder to some other name
          git clone and npm install mine…
          no code changes… just this packaging for rebuild
            JoeFranz @sdetweil
            @sdetweil I renamed the folder and reinstalled the module, this is the result:
            pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm WARN deprecated electron-rebuild@1.11.0: Please use @electron/rebuild moving forward.  There is no API change, just a package name change
            npm ERR! code 7
            npm ERR! path /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
            npm ERR! command failed
            npm ERR! command sh -c node-gyp rebuild
            npm ERR! gyp info it worked if it ends with ok
            npm ERR! gyp info using node-gyp@6.1.0
            npm ERR! gyp info using node@20.8.0 | linux | arm
            npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
            npm ERR! gyp ERR! UNCAUGHT EXCEPTION
            npm ERR! gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
            npm ERR! gyp ERR! stack     at createConfigFile (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/lib/configure.js:118:21)
            npm ERR! gyp ERR! stack     at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/lib/configure.js:85:9
            npm ERR! gyp ERR! stack     at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/mkdirp/index.js:30:20
            npm ERR! gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:189:23)
            npm ERR! gyp ERR! System Linux 6.1.21-v7+
            npm ERR! gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/.bin/node-gyp" "rebuild"
            npm ERR! gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
            npm ERR! gyp ERR! node -v v20.8.0
            npm ERR! gyp ERR! node-gyp -v v6.1.0
            npm ERR! gyp ERR! This is a bug in `node-gyp`.
            npm ERR! gyp ERR! Try to update node-gyp and file an Issue if it does not help:
            npm ERR! gyp ERR!     <https://github.com/nodejs/node-gyp/issues>
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-03T13_57_09_313Z-debug-0.log
              sdetweil @JoeFranz
              @JoeFranz said in MMM-PIR-Sensor not work after v2.25:
              “/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/.bin/node-gyp” “rebuild”
              no… still using the wrong MMM-PIR-Sensor distro
              delete the one you have and do
              git clone
              https://github.com/sdetweil/MMM-PIR-Sensor.git
              cd MMM-PIR-Sensor
              npm install
                JoeFranz @sdetweil
                @sdetweil ok, that worked now, my mistake :-(
                I also made updates for the pi, unfortunately I now also have the latest firmware version: 82f3750a65fadae9a38077e3c2e217ad158c8d54 from March 2023. I’ve had that before, so the monitor on the pi doesn’t go into standby. I now need to downgrade the firmware to version 5.10 (b976c54917e240630c05a9b383010f1492bc61b4). When I try with “sudo rpi-update b976c54917e240630c05a9b383010f1492bc61b4” it says that the firmware is already up to date.
                  sdetweil @JoeFranz
                  @JoeFranz sorry on the firmware, don’t know how to downgrade firmware
                    JoeFranz @sdetweil
                    @sdetweil Ok, I managed it :-)
                    Now everything is working again as it was before the update, thank you again :-)
