    MMM-PIR-Sensor not work after v2.25
    11 Posts 2 Posters 6.3k Views 3 Watching
      sdetweil @JoeFranz
      @JoeFranz if you ran my upgrade script it should fix that
      you MUST install electron-rebuild in the base node_modules and execute it from there while in the module folder.
      see the postinstall script in my fixed fork
      https://github.com/sdetweil/MMM-PIR-Sensor
        JoeFranz @JoeFranz
        @sdetweil after npm install:
        Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall
        node_modules/.bin/electron-rebuild -e …/…/node_modules/electron
        sh: 1: node_modules/.bin/electron-rebuild: not found
        npm ERR! code 127
        npm ERR! path /home/pi/MagicMirror/modules/MMM-PIR-Sensor
        npm ERR! command failed
        npm ERR! command sh -c node_modules/.bin/electron-rebuild -e …/…/node_modules/electron
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-03T12_42_43_352Z-debug-0.log
          sdetweil @JoeFranz
          @JoeFranz did you run this while the command prompt is in the module folder?
            JoeFranz @sdetweil
            @sdetweil yes
              sdetweil @JoeFranz
              @JoeFranz I am confused
              (base) sam@sams:~/MagicMirror/modules$ cd MMM-PIR-Sensor/
              (base) sam@sams:~/MagicMirror/modules/MMM-PIR-Sensor$ npm install
              > ./postinstall
              /home/sam/MagicMirror/modules/MMM-PIR-Sensor
              ⠹ Building module: epoll, Completed: 0make: Entering directory '/home/sam/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
                CXX(target) Release/obj.target/epoll/src/epoll.o
              ⠦ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                COPY Release/epoll.node
              make: Leaving directory '/home/sam/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
              ✔ Rebuild Complete
              added 6 packages, and audited 7 packages in 13s
              found 0 vulnerabilities
              and
              (base) sam@sams:~/MagicMirror/modules/MMM-PIR-Sensor$ ./postinstall
              ✔ Rebuild Complete
              this is HIS BROKEN postinstall which tries to execute it from the MODULE node_modules… which WILL NOT WORK anymore
              I have a script which checks if it is installed in the base, if not installs it and THEN executes it FROM the base (note the leading … to point back to the base… )
              ../../node_modules/.bin/electron-rebuild
              do this
              cd ~/MagicMirror/modules/MMM-PIR_Sensor
              curl -sL https://raw.githubusercontent.com/sdetweil/MMM-PIR-Sensor/master/postinstall >postinstall
              chmod +x postinstall
              ./postinstall
              OR rename the existing module folder to some other name
              git clone and npm install mine…
              no code changes… just this packaging for rebuild
                JoeFranz @sdetweil
                @sdetweil I renamed the folder and reinstalled the module, this is the result:
                pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install
                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                npm WARN deprecated electron-rebuild@1.11.0: Please use @electron/rebuild moving forward.  There is no API change, just a package name change
                npm ERR! code 7
                npm ERR! path /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                npm ERR! command sh -c node-gyp rebuild
                npm ERR! gyp info it worked if it ends with ok
                npm ERR! gyp info using node-gyp@6.1.0
                npm ERR! gyp info using node@20.8.0 | linux | arm
                npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
                npm ERR! gyp ERR! UNCAUGHT EXCEPTION
                npm ERR! gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
                npm ERR! gyp ERR! stack     at createConfigFile (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/lib/configure.js:118:21)
                npm ERR! gyp ERR! stack     at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/lib/configure.js:85:9
                npm ERR! gyp ERR! stack     at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/mkdirp/index.js:30:20
                npm ERR! gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:189:23)
                npm ERR! gyp ERR! System Linux 6.1.21-v7+
                npm ERR! gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/.bin/node-gyp" "rebuild"
                npm ERR! gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                npm ERR! gyp ERR! node -v v20.8.0
                npm ERR! gyp ERR! node-gyp -v v6.1.0
                npm ERR! gyp ERR! This is a bug in `node-gyp`.
                npm ERR! gyp ERR! Try to update node-gyp and file an Issue if it does not help:
                npm ERR! gyp ERR!     <https://github.com/nodejs/node-gyp/issues>
                npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-03T13_57_09_313Z-debug-0.log
                  sdetweil @JoeFranz
                  @JoeFranz said in MMM-PIR-Sensor not work after v2.25:
                  “/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/.bin/node-gyp” “rebuild”
                  no… still using the wrong MMM-PIR-Sensor distro
                  delete the one you have and do
                  git clone
                  https://github.com/sdetweil/MMM-PIR-Sensor.git
                  cd MMM-PIR-Sensor
                  npm install
                    JoeFranz @sdetweil
                    @sdetweil ok, that worked now, my mistake :-(
                    I also made updates for the pi, unfortunately I now also have the latest firmware version: 82f3750a65fadae9a38077e3c2e217ad158c8d54 from March 2023. I’ve had that before, so the monitor on the pi doesn’t go into standby. I now need to downgrade the firmware to version 5.10 (b976c54917e240630c05a9b383010f1492bc61b4). When I try with “sudo rpi-update b976c54917e240630c05a9b383010f1492bc61b4” it says that the firmware is already up to date.
                      sdetweil @JoeFranz
                      @JoeFranz sorry on the firmware, don’t know how to downgrade firmware
                        JoeFranz @sdetweil
                        @sdetweil Ok, I managed it :-)
                        Now everything is working again as it was before the update, thank you again :-)
