    Required Node for MM V2.25.0
    5 Posts 2 Posters 1.2k Views 2 Watching
    • I Offline
      itsmemario1
      Hi everyone, is there a specific or updated script needed just to update the node before updating the MM database?
      I don’t want to use anything else (script) and break what I have currently working. Thanks
      • I Offline
        itsmemario1
        The upgrade script didn’t work, so I went ahead and rebuilt from scratch, had some other modules that also may be non-compliant after the update.
          sdetweil @itsmemario1
          @itsmemario1 see my upgrade script
            @itsmemario1 if you just upgrade node, it will break the app too…
            you can use my upgrade script , it will handle the upgrade the node upgrade too.
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/masterupgrade-script.sh)”
            • I Offline
              itsmemario1
                @itsmemario1 can u send me the upgrade log? did you use the apply.link? did u try upgrade before using the script
                note the script is a 2 part process for upgrade
                test w no changes
                then changes
                if u already upgraded manually, my scripts will abort as I won’t upgrade it again unless you force it.
