    MagicMirror Update & Primordial Error
    5 Posts 2 Posters 739 Views 3 Watching
    • C Offline
      CurlyQ12391
      Hello,
      I know there have been a few errors with the latest update, but the fixes from those posts haven’t worked (yet) for me.
      Like others, I recently updated my MM and now it wont display. pm2 seems to show that it is running but nothing displays on the screen. I troubleshooted myself using other posts and sdetweil’s MagicMirror_scripts, but nothing seems to be working for me. I am 90% sure that my main problem is that my Node version wont update and stays at 16. I’ve tried updating it independently and also through sdetweil’s MagicMirror_scripts (Apply and then using Force) to no avail.
      This is what happens when running sdetweil’s MagicMirror_scripts (Using Force):
      @raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
      Reading package lists... Done
      Building dependency tree... Done
      Reading state information... Done
      The following packages were automatically installed and are no longer required:
        libc-ares2 libjs-highlight.js raspinfo
      Use 'sudo apt autoremove' to remove them.
      The following packages will be REMOVED:
        nodejs*
      0 upgraded, 0 newly installed, 1 to remove and 22 not upgraded.
      After this operation, 185 MB disk space will be freed.
      (Reading database ... 114275 files and directories currently installed.)
      Removing nodejs (20.8.0-1nodesource1) ...
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules' not empty so not removed
      Processing triggers for man-db (2.9.4-2) ...
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      ca-certificates is already the newest version (20210119).
      curl is already the newest version (7.74.0-1.3+deb11u7).
      gnupg is already the newest version (2.2.27-2+deb11u2).
      0 upgraded, 0 newly installed, 0 to remove and 22 not upgraded.
      deb [arch=arm64  signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Get:3 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
      Get:4 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [3,264 B]
      Fetched 15.4 kB in 1s (12.6 kB/s)
      The following package was automatically installed and is no longer required:
        raspinfo
      Use 'sudo apt autoremove' to remove it.
      The following additional packages will be installed:
        libnode72 nodejs-doc
      Suggested packages:
        npm
      The following NEW packages will be installed:
        libnode72 nodejs nodejs-doc
      0 upgraded, 3 newly installed, 0 to remove and 22 not upgraded.
      Need to get 0 B/9,956 kB of archives.
      After this operation, 43.3 MB of additional disk space will be used.
      Selecting previously unselected package libnode72:armhf.
      (Reading database ... 108453 files and directories currently installed.)
      Preparing to unpack .../libnode72_12.22.12~dfsg-1~deb11u4_armhf.deb ...
      Unpacking libnode72:armhf (12.22.12~dfsg-1~deb11u4) ...
      Selecting previously unselected package nodejs.
      Preparing to unpack .../nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb ...
      Unpacking nodejs (12.22.12~dfsg-1~deb11u4) ...
      Selecting previously unselected package nodejs-doc.
      Preparing to unpack .../nodejs-doc_12.22.12~dfsg-1~deb11u4_all.deb ...
      Unpacking nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
      Setting up libnode72:armhf (12.22.12~dfsg-1~deb11u4) ...
      Setting up nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
      Setting up nodejs (12.22.12~dfsg-1~deb11u4) ...
      Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
      doing test run = false
      update log will be in /home/xxx/MagicMirror/installers/upgrade.log
      Check current Node installation ...
      Node currently installed. Checking version number.
      Minimum Node version: v20.8.0
      Installed Node version: v16.17.1
      Node should be upgraded.
      Installing Node.js ...
      The following packages will be upgraded:
        nodejs
      1 upgraded, 0 newly installed, 2 to remove and 22 not upgraded.
      Need to get 0 B/27.0 MB of archives.
      After this operation, 140 MB of additional disk space will be used.
      apt-listchanges: Reading changelogs...
      (Reading database ... 108704 files and directories currently installed.)
      Removing nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
      dpkg: libnode72:armhf: dependency problems, but removing anyway as you requested:
       nodejs depends on libnode72 (= 12.22.12~dfsg-1~deb11u4).
      Removing libnode72:armhf (12.22.12~dfsg-1~deb11u4) ...
      (Reading database ... 108516 files and directories currently installed.)
      Preparing to unpack .../nodejs_20.5.1-deb-1nodesource1_armhf.deb ...
      Unpacking nodejs (20.5.1-deb-1nodesource1) over (12.22.12~dfsg-1~deb11u4) ...
      Setting up nodejs (20.5.1-deb-1nodesource1) ...
      node version is
      Node.js installation Done! version=v16.17.1
      evalmachine.<anonymous>:47
      } = primordials;
      ReferenceError: primordials is not defined
          at evalmachine.<anonymous>:47:5
          at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/fs.js:11:8)
          at Module._compile (node:internal/modules/cjs/loader:1126:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
          at Module.load (node:internal/modules/cjs/loader:1004:32)
          at Function.Module._load (node:internal/modules/cjs/loader:839:12)
          at Module.require (node:internal/modules/cjs/loader:1028:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:3:27)
      } = primordials;
      Check current NPM installation ...
      NPM currently installed. Checking version number.
      } = primordials;
      Minimum npm version: V10.1.0
      Installed npm version: V
      npm should be upgraded.
      Installing npm ...
      E: Unable to correct problems, you have held broken packages.
      } = primordials;
      } = primordials;
      npm installation Done! version=V
      force: line 353: [: -ge: unary operator expected
      saving custom.css
      upgrading from version 2.25.0 to 2.25.0
      fetching latest revisions
      updating MagicMirror runtime, please wait
      force: line 593: [: -ge: unary operator expected
      } = primordials;
      Checking for modules with removed libraries
      processing dependency changes for active modules with package.json files
      processing for module MMM-TouchButton please wait
      } = primordials;
      processing complete for module MMM-TouchButton
      processing for module MMM-ip please wait
      } = primordials;
      processing complete for module MMM-ip
      processing for module MMM-CalendarExt3 please wait
      } = primordials;
      processing complete for module MMM-CalendarExt3
      processing for module MMM-OpenWeatherForecast please wait
      } = primordials;
      processing complete for module MMM-OpenWeatherForecast
      processing for module MMM-Cursor please wait
      } = primordials;
      processing complete for module MMM-Cursor
      restoring custom.css
      Please let me know if you have any suggestions on where to start/go from here.
      *I am having trouble remoting back in, but I’ll post my logs once able.
        sdetweil @CurlyQ12391
        @CurlyQ12391 Yes there is some system error in the installation of node that nobody knows how to fix yet if it’s fixable All of the advice I’ve received doesn’t help
        The primordials problem is one NPM library that’s hacks the file system API to do something extra special but fails on the current version there’s a supposedly hacky way to fix that but I haven’t had a chance to try it on any system want to be the guinea pig?
          @CurlyQ12391 so, if you want to try this
          cd /usr/local/lib/node_modules/npm
          npm install graceful-fs@latest
          cd ~
          node -v
          other than that its rebuild the sd card
          C 1 Reply Last reply Reply Quote 1
          • C Offline
            CurlyQ12391 @sdetweil
            @sdetweil apologies for my delays response.
            I am absolutely willing to be a guinea pig, but I dont think that it ended up doing anything (unless I did it wrong?)
            @raspberrypi:~ $ cd /usr/local/lib/node_modules/npm
            @raspberrypi:/usr/local/lib/node_modules/npm $ npm install graceful-fs@latest
            } = primordials;
            @raspberrypi:/usr/local/lib/node_modules/npm $ cd
            @raspberrypi:~ $ node -v
            v16.17.1
            @raspberrypi:~ $
            Is there a way to increase my node version outside of your installer script? Or would that not help for this particular issue?
            if the best fix is to rebuild SD card and re-install MM I can do that, but I am willing to keep tinkering.
              @CurlyQ12391 I think at the moment it’s better to rebuild
              backup your mm config
              see my backup script
              it will save the config.js, css, and a list of all the module urls
              and can use GitHub to store and version that
              all run from GitHub no required download
