    MMM-Moon shows only "No Image!"
    12 Posts 3 Posters 4.3k Views 3 Watching
    • UncleRogerU Offline
      UncleRoger
      I installed the MMM-Moon module and put in the default config from the git page and all I see is “No Image!”. Has anyone else gotten this to work?
      Here’s my config:
                            module: "MMM-Moon",
      //                      Coordinates for my place:
                              lat: 37.nnnnn,
                              lon: -122.nnnnn,
                              timezone: "America/Los_Angeles"
      UncleRogerU 1 Reply Last reply Reply Quote 0
        UncleRoger @sdetweil
        @sdetweil Thanks to a comment on another thread, I’ve found the answer – I needed to restart the RPi. Once I did that, both the MoonPhase and MMM-Earth modules started working.
          UncleRoger @UncleRoger
          I tried using MMM-MoonPhase and didn’t have any luck there either. Here is my config for that:
                                  module: "MMM-MoonPhase",
                                          updateInterval: 43200000,
                                          hemisphere: "N",
                                          resolution: "detailed",
                                          basicColor: "white",
                                          title: true,
                                          phase: true,
                                          moonAlign: "center",
                                          textAlign: "center",
                                          alpha: 0.7,
                                          riseAndSet: {
                                              display: false,
                                              lat: 37.xxxxx,
                                              lon: -122.xxxxx,
                                              gmtOffset: -8.0
          Here’s what I’m seeing:
          84344962-5bf5-4b2c-852a-366ef454ae69-387451827_1708599592982589_729151378905253751_n.jpg
          I’m starting to think that maybe it’s something more basic with my setup as MMM-SystemStats doesn’t work either (just shows “Loading…” for each item).
          The moon phase isn’t, of course, critical, but it would be nice to get working.
            sdetweil @UncleRoger
            @UncleRoger maybe the api changed (again)
                @UncleRoger cool. never had a module where I needed to reboot to make it work
                • F Offline
                  Fillan90 @sdetweil
                  @sdetweil I got the same issue (No image message), a restart didn’t resolve it.
                    sdetweil @Fillan90
                    @Fillan90 show the module config please, use code block markers
                    paste text
                    select text
                    hit the </> button
                    • F Offline
                      Fillan90 @sdetweil
                      config.js:
                      module: "MMM-Moon",
                                width: "400px",      //    as per requirement
                                height: "400px",       //    as per requirement
                                lat: 59.325,
                                lon: 18.050,
                                timezone: "Europe/Stockholm"
                      MMM-Moon.js:
                      start: function () {},
                        getDom: function () {
                          const outerDiv = document.createElement("div");
                          if (this.content) {
                            const img = document.createElement("img");
                            img.src = this.content;
                            img.style.width = this.config.width || "100%"; // add this line to set the width of the image
                            img.style.height = this.config.height || "auto"; // add this line to set the height of the image
                            outerDiv.appendChild(img);
                          } else {
                            outerDiv.innerText = "No image!";
                          return outerDiv;
                        sdetweil @Fillan90
                        @Fillan90 which MMM-Moon
                        (git remote -v)
                        NEVER edit the source…
                        all config goes in config/config.js
                        all css goes in css/custom.css
                        there is not enough code there to do the job
                        • F Offline
                          Fillan90 @sdetweil
                          [https://github.com/EnderFlop/MMM-Moon](link url)
                            sdetweil @Fillan90
                            @Fillan90 yes, I installed it and used your config and got error 422 (not executed)
                            i’d say that the API changed, but the module hasn’t
                            I see there is a submitted pull request that supposedly fixes this
                            do this
                            cd ~/MagicMirror/modules/MMM-Moon
                            if you changed any files, change them back
                            git status
                            will tell you which were modified
                            git checkout  xxx
                            where xxx is a filename that changed
                            then
                            git fetch origin pull/5/head:pr_branch
                            git checkout  pr_branch
                            then restart mm
                            F 1 Reply Last reply Reply Quote 1
                            • F Offline
                              Fillan90 @sdetweil
                              That fixed it, thank you so much.
                              /F
