    MM digital display hung like a picture
    24 Posts 9 Posters 13.2k Views 9 Watching
      rrslssr @rmonkey
      @rmonkey I have started searching for a picture frame to use for the display.
      Would you please tell me the size of the picture frame you used?
        jbat66 @rmonkey
        @rmonkey If you use MMM-BackgroundSlideShow, it has a radial option that is basically a vignette.
          rmonkey
          @rrslssr , I took the monitor to Michaels and asked for a custom frame and matte. I told them I wanted a 2.5" mat out to the frame (make sure to specify the display only, not display plus bezels).
          Then I picked a frame that I liked that met the minimum depth requirements for the Pi Zero 2.
          I also made sure I got gallery glass, which has an antireflective coating.
          They kept messing up the matte and I ended up going to Hobby Lobby. They recut the matte correctly and even cut the foam core used to hold everything in place.
            rmonkey
            @jbat66, that’s fantastic. I’ll experiment with that when I do a refresh of the whole deal. Thank you!
            • 3 / 3
