    Modifying the Config File
    101 Posts 7 Posters 174.0k Views 7 Watching
      sdetweil @jimb
      @jimb ssh user @ hostname
      every command supports help
      command_name -h or --h
        jimb
        Sam, the username seems to be OK, but the hostame doesn’t resolve. Even though it shows in preference. Am I missing something
          sdetweil @jimb
          @jimb try adding .local after the hostname
          or use the IP address of the pi.
            jimb
            Sam, beating head against rock… local host didn’t work. I was able to resolve an IP address, but it appeared to be a v6 that would.t work with ssh. I don’t know the next step.
              jimb
              Sam, since I’m not making any progress on the weather module I’m going to remark all the lines out for now and move on to other modules.
                sdetweil @jimb
                @jimb ok the address was probably raspberrypi.local
                you need to disable ipv6 on the pi, in the network settings of the pi config under the desktop menu
                no reason to have ipv6 in a home environment
                  jimb
                  Sam, no joy on either suggestion. Would it be worth it to start the MM install over again. I couldn’t ‘remark’ out the lines, just caused an error with the config file.
                  I bought the Rasberry Pi with a pre-populated SIM. Not how to get it in virgin state.
                    sdetweil @jimb
                    @jimb you can just copy the config.js.sample over/instead of config.js
                    cd ~/MagicMirror/config
                    mv config.js config.js.save
                    cp config.js.sample config.js
                    now MM is back to new, and we saved the config you have
                      jimb
                      Sam, OK the sample file has been renamed to just config.js. When running the new config with ‘npm start dev’ the weather section now says 'loading on both lines (current & forecast) and it still has two entries with "401 unauthorized). Also, error with “could not load data” on two lines. Should I add my API ID to both sections of the config or?
                      S BKeyportB 2 Replies Last reply Reply Quote 0
                        sdetweil @jimb
                        @jimb good place to start.
                        • BKeyportB Offline
                          BKeyport Module Developer @jimb
                          @jimb https://docs.magicmirror.builders/modules/configuration.html would be great to read - tells you how to set up the default modules to run. Once you get that, you can get going on any replacements you’d like to run.
                            jimb
                            BKeyport, thanks for the hint! I have worn out the config docs reading 'em. No matter what I do I can’t past the “401 unauthorized” when MM tries to load the weather data. I get a partial diplay of the weather stuff. Sam has been more that patient with me and I’d hate to wear out my welcome here.
                            Does anyone know how to get the Pi back to the start? I feel like I’m not going to make real progress until I can use the IP address to SSH into the Pi so I can copy the config file here so it can be seen. I didn’t make a note of it when I ‘built’ the Pi.
                              sdetweil @jimb
                              @jimb open a terminal window, ctrl-alt-t,on the desktop
                              type
                              ip addr
                              press enter
                              you should get both the ipv4 and ipv6 addresses of the pi
                              then type
                              hostname
                              enter
                              should give you the pi hostname on the network, you should be able to use this in the ssh command
                              ssh  {username}@{hostname}
                              {x} means substitute the value of the thing x for the whole string
                              • BKeyportB Offline
                                @jimb If you’re thinking you’re FUBAR, you can always boot a fresh image (Raspberry Pi Imager, preferably, other methods available, search for Raspberry Pi Recovery Mode)
                                If you do build a new image, take a look at the advanced options in the Imager - You can pre-set things that’ll make life a ton easier - like hostnames, SSH availability, username/passwords, etc. Make sure to have the newest version of the imager, and it’ll remind you to look at the settings every time, rather than have it be a different workflow.
                                That being said, if you just need to dump Magic Mirror, delete the directory tree and start over - using Sam’s exceptional script this time to set it up. Good chance that gets it going.
                                What I do personally, is use combinations of SAMBA, Geany, VNC & SSH to get everything up and running fully remote, but that’s a bit advanced - Geany is on the Pi desktop, so if you want to try to use that to edit your config files, great, makes it so much easier.
                                  sdetweil @BKeyport
                                  @BKeyport don’t edit ON the pi, use Winscp or Bitvise SSH clients, then you can use your pc editor and keyboard, mouse… and double click to edit, and still have a terminal window via ssh…
                                  one the wall enclosed, or just developing, its exactly the same. and you can multiple systems open at once…
                                  I use Notepad++ or VisualStudio code…
                                  then u have brace matching and indentation matching… REALLY makes life easier…
                                  AND you can use your PC browser to access MM on the pi, so its all right there… laptop, desktop doesn’t matter…
                                  bitvise also has a server side(pc) file manager window so you can drag/drop files in either direction (altho you dont usually need to.)…
                                  all my scripts work thru ssh, MM runs there too… and you can use pm2 just like always…
                                  • BKeyportB Offline
                                    @sdetweil Fair enough, I was applying a bit of KISS (Keep It Simple, Stupid) suggesting at least initial edits can be done locally - don’t want to overwhelm.
                                      sdetweil @BKeyport
                                      @BKeyport I know, but learning all the commands, keyboard, gui tools, menus, settings, etc, is overwhelming for many people.
                                        jimb
                                        Sam, I’m trying to get to the point where I can copy/paste the config where you can take a look at it. It’s been 45 years since I looked at Unix, never Linux.
                                        IP Config from the OS prompt on the Pi yields -
                                        “Link/loopback 'all zeros…”
                                        “inet 127.0.0.0/8 scope host lo”
                                        NOT a valid IP address, it should be in the range of 192.168. x.x
                                        hostname command from the Pi gives “rutspi” which is the hostname I assigned as it was building.
                                        S bheplerB 2 Replies Last reply Reply Quote 0
                                          sdetweil @jimb
                                          @jimb if that is the only ip address, then it is not on your wifi or Ethernet networks.
                                          127.0.0.1 is the fake internal only network
                                          • BKeyportB Offline
                                            sounds to me like too much tinkering got the network FUBAR.
                                            I’d reset and start over, personally.
                                            • 6
                                            • 3 / 6
