    ERROR:gbm_wrapper.cc(253) Failed to export buffer to dma_buf: No such file or directory
    15 Posts 3 Posters 10.9k Views 3 Watching
      dathbe @sdetweil
      @sdetweil Ok. When I have some time, I’m going to test an install with 32-bit PiOS.
        sdetweil @dathbe
        @dathbe 32bit is x11 only . as i recall
          dathbe @sdetweil
          @sdetweil It appears to load labwc by default, but either way it didn’t do anything different – fails to start with start:wayland and multiple phantom errors with start. I guess I just have to close my eyes and not read the logs on startup. Though weird it’s doing it with my Pi 4B, but not my Pi 2B.
            sdetweil @dathbe
            @dathbe yeh some config setup, i think something in /boot/config. txt
              dathbe @sdetweil
              @sdetweil In case for some reason it’s helpful, I’ve reviewed the contents of /boot/config.txt from my two devices (4B gets errors, 2B does not).
              In 2B, not in 4B:
              #dtoverlay=vc4-kms-v3d
              # see https://forums.raspberrypi.com/viewtopic.php?p=1507622#p1507247
              dtoverlay=vc4-fkms-v3d
              In 4B, not in 2B:
              # Run in 64-bit mode
              arm_64bit=1
              [cm5]
              dtoverlay=dwc2,dr_mode=host
