    npm start Problem
    16 Posts 2 Posters 5.3k Views 2 Watching
    • L Offline
      Lockslay @sdetweil
      file /usr/local/bin/node
      /usr/local/bin/node: ELF 64-bit LSB executable, x86-64, version 1 (GNU/Linux), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=d6aa6eb3474758fb4e621dac8db78891d4f4c0ef, for GNU/Linux 3.2.0, with debug_info, not stripped, too many notes (256)
      Sorry,
      I hadn’t seen the message
        sdetweil @Lockslay
        @Lockslay yeh, something installed the 64 bit v of node on your 32 bit system.
        let’s try this
        sudo apt-get remove nodejs
        then
         node - v
        • L Offline
          Lockslay @sdetweil
          @sdetweil said in npm start Problem:
          node - v
          __
          dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/man/man7’ not empty so not removed
          dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/man/man5’ not empty so not removed
          dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/man/man1’ not empty so not removed
          dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/lib/utils’ not empty so not removed
          dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/docs/output/using-npm’ not empty so not removed
          dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/docs/output/configuring-npm’ not empty so not removed
          dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/docs/output/commands’ not empty so not removed
          dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules/npm/bin’ not empty so not removed
          Processing triggers for man-db (2.9.4-2) …
          stefan@smartmirror:~ $ node - v
          -bash: /usr/local/bin/node: cannot execute binary file: Exec format error
            sdetweil @Lockslay
            @Lockslay ok, next
            sudo rm -rf /usr/lib/node_modules/npm
            sudo rm  /usr/local/bin/node
            which node
            hash -r
            which node
            node -v
            • L Offline
              Lockslay @sdetweil
              @sdetweil Thanks for your help, isn’t it better to reinstall?
              I just realised that the config is no longer there either
                sdetweil @Lockslay
                @Lockslay yes, probably.
                flash SD card
                boot
                skip updates
                use my script
                if u back up w my other script
                I will restore the config, css, and modules on top.of the new mm after install
