    Crashing after "Starting Server"
    13 Posts 3 Posters 2.8k Views 4 Watching
      BEGreen87
      Hey Gang,
      I run MagicMirror in a Docker Container and started running into an issue yesterday where it seems to crash after reaching " —Starting Server—". Just prior to this I had rebooted the Container and the page worked for 1-2hrs until it froze.
      Updates on the container are disabled after a past learning event since things were stable, although I did update during troubleshooting efforts.
      The following log is on constant loop:
      > magicmirror@2.25.0 server
      > node ./serveronly
      [20.11.2023 11:27.12.528] [LOG]   Starting MagicMirror: v2.25.0
      [20.11.2023 11:27.12.530] [LOG]   Loading config ...
      [20.11.2023 11:27.12.532] [DEBUG] config template file not exists, no envsubst
      [20.11.2023 11:27.12.535] [LOG]   Loading module helpers ...
      [20.11.2023 11:27.12.536] [LOG]   No helper found for module: alert.
      [20.11.2023 11:27.12.544] [LOG]   Initializing new module helper ...
      [20.11.2023 11:27.12.545] [LOG]   Module helper loaded: updatenotification
      [20.11.2023 11:27.12.546] [LOG]   No helper found for module: clock.
      [20.11.2023 11:27.12.670] [ERROR] Whoops! There was an uncaught exception...
      [20.11.2023 11:27.12.672] [ERROR] Error: Cannot find module 'fetch'
      Require stack:
      - /magicmirror2/modules/default/calendar/calendarfetcher.js
      - /magicmirror2/modules/default/calendar/node_helper.js
      - /magicmirror2/js/app.js
      - /magicmirror2/serveronly/index.js
          at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
          at Module._resolveFilename (/magicmirror2/node_modules/module-alias/index.js:49:29)
          at Module._load (node:internal/modules/cjs/loader:922:27)
          at Module.require (node:internal/modules/cjs/loader:1143:19)
          at require (node:internal/modules/cjs/helpers:121:18)
          at Object.<anonymous> (/magicmirror2/modules/default/calendar/calendarfetcher.js:11:15)
          at Module._compile (node:internal/modules/cjs/loader:1256:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
          at Module.load (node:internal/modules/cjs/loader:1119:32)
          at Module._load (node:internal/modules/cjs/loader:960:12)
          at Object.<anonymous> (/magicmirror2/modules/default/calendar/node_helper.js:8:25)
          at Module.load (node:internal/modules/cjs/loader:1119:32) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/magicmirror2/modules/default/calendar/calendarfetcher.js',
          '/magicmirror2/modules/default/calendar/node_helper.js',
          '/magicmirror2/js/app.js',
          '/magicmirror2/serveronly/index.js'
      [20.11.2023 11:27.12.673] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [20.11.2023 11:27.12.673] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      ---Ensuring UID: 99 matches user---
      usermod: no changes
      ---Ensuring GID: 100 matches user---
      usermod: no changes
      ---Setting umask to 000---
      ---Checking for optional scripts---
      ---No optional script found, continuing---
      ---Taking ownership of data...---
      ---Starting...---
      ---MagicMirror² up-to-date---
      ---Looking for new modules to install---
      Module 'MMM-GoogleCalendar' found!
      Module 'MMM-GooglePhotos' found!
      Module 'MMM-WeatherGraph' found!
      Module 'MMM-MyCommute' found!
      Module 'MMM-MonthlyCalendar' found!
      Module 'MMM-WebHookAlerts' found!
      Module 'MMM-WeasleyClock' found!
      Module 'MMM-NotificationReceived' found!
      Module 'MMM-TracCar' found!
      Module 'MMM-WiFiPassword' found!
      Module 'MMM-GoogleDocs-Notes' found!
      ---Preparing Server---
      ---Configuration file found!---
      ---Please wait, permissions are set, this can take some time...---
      ---Starting Server---
      I’m not sure if this is related to “Error: Cannot find module ‘fetch’”, but went ahead and tried the suggestions over here (this was for “node-fetch” while it looks like mine is just “fetch”).
      Thanks in advance for the help.
        sdetweil @BEGreen87
        @BEGreen87 sounds like the npm install was not done after the code update
          BEGreen87 @sdetweil
          @sdetweil Thanks for the reply. Tried again:
          Here’s result from “npm install node-fetch@2”:
          up to date, audited 153 packages in 1s
          12 packages are looking for funding
            run `npm fund` for details
          11 vulnerabilities (5 moderate, 6 high)
          To address issues that do not require attention, run:
            npm audit fix
          Some issues need review, and may require choosing
          a different dependency.
          Run `npm audit` for details.
          and “npm install”:
          up to date, audited 153 packages in 879ms
            npm audit fix
          Started to look at the vulnerabilities with ‘npm audit’:
          npm audit report
          connect  <=2.30.2
          Severity: high
          methodOverride Middleware Reflected Cross-Site Scripting in connect - https://github.com/advisories/GHSA-3fw8-66wf-pr7m
          Cross-Site Scripting in connect - https://github.com/advisories/GHSA-rch9-xh7r-mqgw
          Node Connect Reflected Cross-Site Scripting in Sencha Labs Connect middleware - https://github.com/advisories/GHSA-6w62-83g6-rfhj
          Depends on vulnerable versions of cookie-signature
          Depends on vulnerable versions of fresh
          Depends on vulnerable versions of qs
          Depends on vulnerable versions of send
          fix available via `npm audit fix`
          node_modules/connect
            express  <=4.15.4 || 5.0.0-alpha.1 - 5.0.0-alpha.5
            Depends on vulnerable versions of connect
            node_modules/hooks-node/node_modules/express
              hooks-node  *
              Depends on vulnerable versions of express
              Depends on vulnerable versions of request
          cookie-signature  <1.0.4
          Severity: moderate
          cookie-signature Timing Attack - https://github.com/advisories/GHSA-92vm-wfm5-mxvv
          node_modules/connect/node_modules/cookie-signature
          node_modules/hooks-node/node_modules/cookie-signature
          fresh  <0.5.2
          Severity: high
          Regular Expression Denial of Service in fresh - https://github.com/advisories/GHSA-9qj9-36jm-prpv
          node_modules/connect/node_modules/fresh
          node_modules/hooks-node/node_modules/fresh
            send  <=0.15.6
            Depends on vulnerable versions of mime
            node_modules/connect/node_modules/send
            node_modules/hooks-node/node_modules/send
          mime  <1.4.1
          Severity: high
          mime Regular Expression Denial of Service when MIME lookup performed on untrusted user input - https://github.com/advisories/GHSA-wrvr-8mpx-r7pp
          node_modules/connect/node_modules/mime
          node_modules/hooks-node/node_modules/mime
          qs  <=6.2.3
          Severity: high
          Prototype Pollution Protection Bypass in qs - https://github.com/advisories/GHSA-gqgv-6jq5-jjj9
          Denial-of-Service Extended Event Loop Blocking in qs - https://github.com/advisories/GHSA-f9cm-p3w6-xvr3
          Denial-of-Service Memory Exhaustion in qs - https://github.com/advisories/GHSA-jjv7-qpx3-h62q
          qs vulnerable to Prototype Pollution - https://github.com/advisories/GHSA-hrpp-h998-j3pp
          node_modules/connect/node_modules/qs
          request  *
          Severity: moderate
          Server-Side Request Forgery in Request - https://github.com/advisories/GHSA-p8p7-x288-28g6
          Depends on vulnerable versions of tough-cookie
          No fix available
          node_modules/request
            fetch-node  *
            Depends on vulnerable versions of hooks-node
            node_modules/fetch-node
          tough-cookie  <4.1.3
          Severity: moderate
          tough-cookie Prototype Pollution vulnerability - https://github.com/advisories/GHSA-72xf-g2v4-qvf3
          No fix available
          node_modules/tough-cookie
            npm audit fix
          No dice with “npm audit fix” or “npm audit fix --force”. Ended up deleting package-lock.json and the node_modules directory to reset everything.
          Result of “npm install”:
          > magicmirror@2.25.0 postinstall
          > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
          > magicmirror@2.25.0 install-vendor
          > echo "Installing vendor files ...
          > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          up to date in 346ms
          > magicmirror@2.25.0 install-fonts
          > echo "Installing fonts ...
          > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          up to date in 285ms
          > magicmirror@2.25.0 prepare
          > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
          fatal: not a git repository (or any parent up to mount point /)
          Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
          husky - git command not found, skipping install
          added 862 packages, and audited 863 packages in 39s
          199 packages are looking for funding
          found 0 vulnerabilities
          No dice yet… Also tried to get things to run between these steps.
            MMRIZE @BEGreen87
            @BEGreen87
            “fetch” is introduced since node 18. Your log seems fetch is not provided natively and it means your node version might be somehow older than nodev18.
              BEGreen87 @MMRIZE
              @MMRIZE Thanks for the help. Is there a configuration that needs to be set around node?
              Here’s what “node -v” returns:
              v18.17.1
              Noticed it wasn’t the latest so went through the following:
              npm install -g n
              n lts
              n prune
              Now “node -v” returns:
              v20.9.0
              Still having the same issue, log after update below:
              > node ./serveronly
              [20.11.2023 15:43.16.311] [LOG]   Starting MagicMirror: v2.25.0
              [20.11.2023 15:43.16.313] [LOG]   Loading config ...
              [20.11.2023 15:43.16.315] [DEBUG] config template file not exists, no envsubst
              [20.11.2023 15:43.16.319] [LOG]   Loading module helpers ...
              [20.11.2023 15:43.16.320] [LOG]   No helper found for module: alert.
              [20.11.2023 15:43.16.331] [LOG]   Initializing new module helper ...
              [20.11.2023 15:43.16.331] [LOG]   Module helper loaded: updatenotification
              [20.11.2023 15:43.16.332] [LOG]   No helper found for module: clock.
              [20.11.2023 15:43.16.449] [ERROR] Whoops! There was an uncaught exception...
              [20.11.2023 15:43.16.453] [ERROR] Error: Cannot find module 'fetch'
              Require stack:
                  at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
                  at Module._load (node:internal/modules/cjs/loader:901:27)
                  at Module.require (node:internal/modules/cjs/loader:1115:19)
                  at require (node:internal/modules/helpers:130:18)
                  at Module._compile (node:internal/modules/cjs/loader:1241:14)
                  at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
                  at Module.load (node:internal/modules/cjs/loader:1091:32)
                  at Module._load (node:internal/modules/cjs/loader:938:12)
                  at Module.load (node:internal/modules/cjs/loader:1091:32) {
                requireStack: [
              [20.11.2023 15:43.16.453] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [20.11.2023 15:43.16.453] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              usermod: no changes
              usermod: no changes
              ---Starting...---
                sdetweil @BEGreen87
                @BEGreen87 what is all that junk at the end?
                  sdetweil @BEGreen87
                  @BEGreen87 move the mm folder out of the way
                  and run my install script
                  you may want to backup your mirror setup and restore after
                    MMRIZE @BEGreen87
                    @BEGreen87
                    Require stack:
                    This is very weird log, because calendarfetcer.js doesn’t call require("fetch") in the source, so there is no reason of that error. Is the source modified? Can you check the source is the same with original?
                    B 2 Replies Last reply Reply Quote 0
                      BEGreen87 @MMRIZE
                      @MMRIZE Looks like I match the 2.23.0 Release.
                        BEGreen87 @MMRIZE
                        @MMRIZE @sdetweil
                        Thanks for all the help, was able to resolve the issue by replacing all the files in /modules/default/calendar with the ones for the latest release.
                        Not sure why this didn’t occur during the update, but looks like I’m back in business!
                          sdetweil @BEGreen87
                          @BEGreen87 weird
                          from the MagicMirror folder do
                          git status
                          and report the results if you can
                            BEGreen87 @sdetweil
                            Guessing this is because I’m using using it in Docker?
                              sdetweil @BEGreen87
                              @BEGreen87 yeh, maybe
