    Raspberry Pi Zero W for Magic Mirror
    79 Posts 10 Posters 78.9k Views 11 Watching
    • A
      Arno123
      Hi All,
      I’m new to this forum, and also new to the world of Magic Mirror
      Looking to get into this, so readup on the possibility of using the Pi Zero 2W, but get alot of conflicting messages, where some say the 512Mb is not enough, but others say its sufficiant, albeit it might be slightly slow at times
      I tried to configure the Pi Zero by running the desktop version, but could not get Magic Mirror to install / run (keeps on failing due to unsuported OS) … Lateron I mange to get it to run using only the Lite OS ( ie no desktop ) … so far so good, but keen to hear some views
      So questions few then,
      a) Any of you running Magic Mirror on the Pi Zero 2W, and if so - how is it configured (Desktop / Lite) ?
      b) Can I run / use some form of PIR / Camera to detect someone to swich the LCD on/off - again, any issues ?
      c) Any other issues I might need to be aware off ?
      If the Zero is not ideal, what other Pi should I consider [ thinking my other board - a Pi4 4Gig, might be somewhat of an overkill ? ] – but wanna hear from you guys with bit more experience than me on this topic
      Cheers !
        sdetweil @Arno123
        @Arno123 it’ll run just fine
        flash the SD card, boot, skip updates, and run my install script. it will do everything needed.
        see
        as part of the install it will increase the swap space.
        A 2 Replies Last reply
        Reply Quote 2
        • A
          Arno123 @sdetweil
          @sdetweil Excellent
          Thank you, I’ll give this a go!
          • A
            Arno123 @sdetweil
            @sdetweil This works an absolute treat, thank you!
            Reply Quote 1
              sdetweil @Arno123
              @Arno123 awesome!
              • mariosgourosM
                mariosgouros
                Mine works with a pi zero w 2 and I am very satisfied with the way it performs. I followed the official procedure as described in the forums and got it working on buster os desktop which is essential for some modules. Used to run the project on pi zero w with buster os lite and for basic and simple stuff the project used to run fine minus some lags when refreshing modules but nothing special.
                As I decided to run more demanding modules running pi zero w 2 was the only solution to keep the project small and low cost. For the modules I am using I’m for than satisfied with the way it performs.
                Anyway, all I can confirm is that magic mirror on pi zero w 2 with buster os desktop can perform nice.
                • JakobudJ
                  Jakobud
                  I recently got a RPi Zero 2W and installed Raspberry Pi OS (latest legacy version from the RPi Imager) and then installed MM2 using the script (which worked really well). But Chromium will not run for me. Everything I read says that Chromium will not work on the RPi Zero 2 because it’s not fast enough or doesn’t have enough memory. Chromium absolutely will not start on mine. What am I missing here?
                    sdetweil @Jakobud
                    @Jakobud hm… try the not legacy image, runs great on my pi02w
                    legacy really for armv6l
                    are you using the full image?
                    JakobudJ 1 Reply Last reply
                    • JakobudJ
                      Jakobud @sdetweil
                      After choosing RPi Zero 2 W it recommends this one to me, which is what I used. What version should I be using instead exactly?
                        sdetweil @Jakobud
                        @Jakobud I don’t use the raspberry imager cause of problems and this filtering
                        I use the list and then image myself
                        https://www.raspberrypi.com/software/operating-systems/#raspberry-pi-os-64-bit
                        • JakobudJ
                          Jakobud @sdetweil
                          @sdetweil Okay which one do you use specifically?
                            sdetweil @Jakobud
                            @Jakobud the top one on that page
                            D 1 Reply Last reply
                            • D
                              davidgagne @sdetweil
                              @sdetweil I am ripping my hair out trying to get MM running on a Pi Zero W. I’ve followed all of your (super helpful) suggestions across multiple posts, but no matter what I do, I keep getting:
                              [PM2][ERROR] File ecosystem.config.js not found
                              any time I try to execute pm2 start.
                              I’ve run your upgrade / update scripts from github, I’ve removed Chromium and replaced it with Firefox, I’ve uninstalled and reinstalled ten different flavors of the PiOS, I’ve tried the MagicMirrorOS that someone else posted, etc. All with no luck.
                              Do you have any ideas what could be the problem here?
                              Thanks in advance,
                              dvg
                                sdetweil @davidgagne
                                @davidgagne said in Raspberry Pi Zero 2 W for Magic Mirror:
                                File ecosystem.config.js no found
                                well, I haven’t seen that…, BUT it sounds like from a google search thgat you have the wrong node js version installed…
                                but
                                flash the sd card… its a pi02W, a 3 in pi0 form factor
                                then run my install script. don’t dop anything else first
                                you can try to see if you can fixup pm2 first…
                                pm2 stop all
                                pm2 status
                                this will display a line
                                pi@raspberrypi42:~ $ pm2 status
                                │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.7mb    │
                                you can use the name or number on any line
                                pm2 delete 0
                                pm2 save -f
                                then run
                                bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
                                to recreate the app in pm2.
                                lets see…
                                else redo the install as above
                                Reply Quote 1
                                • D
                                  @sdetweil said in Raspberry Pi Zero 2 W for Magic Mirror:
                                  I’m sorry but I don’t understand what this means. Which PiOS should I flash? I have been trying with the Legacy, 32-bit.
                                  (If it makes a difference, I actually have a Raspberry Pi Zero W Rev 1.1. I don’t think it’s a 2.)
                                  Thank you!
                                    @davidgagne ok, if it IS a pi0W, then 32 bit legacy image
                                    flash sd card, boot to the desktop, use terminal window or ssh
                                    then my install script.
                                    they have removed the chromium browser, for armv6l, so you will have to use firefox or one of the others… midori or surf
                                    so YOU MUST use the environment variable in
                                    ~/MagicMirror/installers/mm.sh to set the browser to use ( all have to be installed manually)
                                    • D
                                      @sdetweil Okay. I’m doing this right now.
                                      1. Flashed card with Legacy 32-bit.
                                      2. Connected via ssh to run your script.
                                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                        Answered yes to disable screen saver and use pm2 questions.
                                      3. Removed chromium with:
                                        sudo apt-get remove chromium-browser
                                        sudo apt autoremove
                                      4. Added Firefox with:
                                        sudo apt-get update
                                        sudo apt-get install firefox-esr
                                      5. Enabled VNC using sudo raspi-config GUI
                                      6. Connect via TigerVNC
                                      7. Edit mm.sh via VNC in Pi's baked-in text editor by adding:
                                        cd ~/MagicMirror
                                        export external_browser=firefox
                                        DISPLAY=:0 npm start
                                      8. sudo reboot
                                      9. Connect via ssh
                                      10. cd MagicMirror
                                        pm2 start MagicMirror
                                      11. And now -- finally! -- some progress:
                                        [PM2] Spawning PM2 daemon with pm2_home=/home/dvg/.pm2
                                        [PM2] PM2 Successfully daemonized
                                        [PM2][ERROR] Script not found: /home/dvg/MagicMirror/MagicMirror
                                      So … now what have I done wrong? What script is missing?
                                        @davidgagne well…
                                        it seems the pm2 setup failed for some reason
                                        can you send me the ~/install.log
                                        my same userid at Gmail.
                                        you didn’t have to vnc to edit, nano works over ssh.
                                        because the pm2 setup was not completed,
                                        when you did pm2 start from the MagicMirror folder, it was trying to create the app MagicMirror command
                                        /home/username/MagicMirror/MagicMirror
                                        can you try to run the fixuppm2 script from my scripts page
                                        • D
                                          @sdetweil Here’s what I got after running your fixup script:
                                          [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                                          [PM2] [MagicMirror](0) ✓
                                          │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                                          │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 27952    │ 0s     │ 1    │ online    │ 0%       │ 2.5mb    │ dvg      │ enabled  │
                                          [PM2] Saving current process list...
                                          [PM2] Successfully saved in /home/dvg/.pm2/dump.pm2
                                          I’ll email install.log to you as soon as I can figure out how to … find and copy the install log.
                                          S 2 Replies Last reply
                                            @davidgagne and MagicMirror should have come up using firefox
                                            • 1 / 4
