    Magicmirror in Kubernetes
    3 Posts 2 Posters 695 Views 2 Watching
    • G Offline
      gerbenvs
      Hello,
      I do want to run Magicmirror in my Kubernetes cluster, but the image doesn’t start.
      When the pod is starting, it’s crashing with this error:
      magicmirror@2.25.0 server
      node ./serveronly
      node:internal/modules/cjs/loader:1147
      throw err;
      Error: Cannot find module ‘/opt/magic_mirror/js/…/modules/default/defaultmodules’
      Require stack:
      • /opt/magic_mirror/js/app.js
      • /opt/magic_mirror/serveronly/index.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1144:15)
        at Module._resolveFilename (/opt/magic_mirror/node_modules/module-alias/index.js:49:29)
        at Module._load (node:internal/modules/cjs/loader:985:27)
        at Module.require (node:internal/modules/cjs/loader:1235:19)
        at require (node:internal/modules/helpers:176:18)
        at Object. (/opt/magic_mirror/js/app.js:17:24)
        at Module._compile (node:internal/modules/cjs/loader:1376:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1435:10)
        at Module.load (node:internal/modules/cjs/loader:1207:32)
        at Module._load (node:internal/modules/cjs/loader:1023:12)
        at Object. (/opt/magic_mirror/serveronly/index.js:1:13)
        at Module.load (node:internal/modules/cjs/loader:1207:32) {
        code: ‘MODULE_NOT_FOUND’,
        requireStack: [
        ‘/opt/magic_mirror/js/app.js’,
        ‘/opt/magic_mirror/serveronly/index.js’
      Node.js v20.10.0
      npm notice
      npm notice New patch version of npm available! 10.2.3 -> 10.2.5
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.2.5
      npm notice Run npm install -g npm@10.2.5 to update!
      npm notice
      When I login to the pod and run ’ npm run server’, I do see the same message.
      I have mounted /config, /css and /modules to persistent volumes. Because this is an initial deployment, all volumes are still empty.
      Any ideas?
      Gerben
      • G Offline
        gerbenvs @gerbenvs
        I think I have the solution for this error.
        Had to run the entrypoint.sh script. That copies all default modules to correct folder.
        • karsten13K Offline
          karsten13 @gerbenvs
          @gerbenvs
          I played around with a helm and a kustomize setup …
