    MMM-Face-Reco-DNN
    20 Posts 2 Posters 7.7k Views 2 Watching
      danningson @sdetweil
      @sdetweil I’m not sure. I typed in env and got back a whole bunch of stuff i don’t understand
        sdetweil @danningson
        @danningson usually the terminal window prompt has the active python venv name prepended
        (base) here on my system
        (base) sam@sams:~/MagicMirror$
          @sdetweil Ah, this pi is only intended for the mirror so i simply named it mm
          mm@raspberrypi:~/MagicMirror $
            @sdetweil I just ran the install script again and now i get this:
            (python-facereco) mm@raspberrypi:~/MagicMirror $
              @danningson ok, and NOW does facereco work?
                @sdetweil sorry, I should have included that in my response. No sadley I get no recognition or even an unknown face. The items with classes do not show, which is correct but it is as if the cammera is not seeing anything but I know it works.
                  @sdetweil I came up with the briliant ide a to reboot the pi and now the (python-facereco) is gone as well. and yes, still no reaction from the camera
                    @danningson you need to add the venv setup to the ~/.bashrc
                    so it’s always set when a script is run
                      @sdetweil It works!! Thank you for all your help! although i am back to nat having the (python-facereco) anymore it works and recgonizes both my wife and myself.
                      Thanks for your time and and expertise on this.
                        @danningson awesome
