    MMM-Face-Reco-DNN
    20 Posts 2 Posters 8.6k Views 2 Watching
      danningson @sdetweil
      @sdetweil Hi Sam - first, thank you for your time and expertise. I really do appreciate all the help. looks like you were right. I went back and ran the script again and noticed the environment additions. After running those I was able to run the encode.py program and it added several of the new pics i took. To further my troublshooting i added several classes as unknow. My thought was if the camera is seeing me but not recognizing me at least those moduels would show up and tell me the program was working correctly. Unfortunatly I got no reaction when looking into the camera either known or unknown. the camera is still wotking with the libcamera-still -o test.jpg so I am not sure why the program is failing to pic up anything. Again, thanks for your help
        sdetweil @danningson
        @danningson is mm running under that venv?
          @sdetweil I’m not sure. I typed in env and got back a whole bunch of stuff i don’t understand
            @danningson usually the terminal window prompt has the active python venv name prepended
            (base) here on my system
            (base) sam@sams:~/MagicMirror$
              @sdetweil Ah, this pi is only intended for the mirror so i simply named it mm
              mm@raspberrypi:~/MagicMirror $
                @sdetweil I just ran the install script again and now i get this:
                (python-facereco) mm@raspberrypi:~/MagicMirror $
                  @danningson ok, and NOW does facereco work?
                    @sdetweil sorry, I should have included that in my response. No sadley I get no recognition or even an unknown face. The items with classes do not show, which is correct but it is as if the cammera is not seeing anything but I know it works.
                      @sdetweil I came up with the briliant ide a to reboot the pi and now the (python-facereco) is gone as well. and yes, still no reaction from the camera
                        @danningson you need to add the venv setup to the ~/.bashrc
                        so it’s always set when a script is run
                          @sdetweil It works!! Thank you for all your help! although i am back to nat having the (python-facereco) anymore it works and recgonizes both my wife and myself.
                          Thanks for your time and and expertise on this.
                            @danningson awesome
