    MMM-Face-Reco-DNN
    20 Posts 2 Posters 8.6k Views 2 Watching
      sdetweil @danningson
      @danningson the code just sends the name of the user up to the module, which hides all the modules without that name as a class
      I don’t know if there is any debug info provided
        danningson @sdetweil
        @sdetweil yes, that’s one of the things I loved about this module. It’s like a free screen saver when no face is detected. I had to set several modules ad always for my trouble shooting since it is not detecting anything.
          @danningson you should see messages where you start MM
          I STRONGLY suggest NOT using pm2 during modules dev and testing
          pm2 stop all
          npm start >somefile.txt 2>&1
          then all the messages will be in somefile.txt
          ctrl-c in terminal window or ctrl-q on MM web page to stop
          here is a message in the node_helper that should be triggered
          console.log(‘[’ + self.name + '] ’ + ‘Users ’ + message.login.names.join(’ - ‘) + ’ logged in.’);
          there is also a camera frame event but no logging, you could add a message there
          all the CV work is done in python in the background, and its outputs messages to the handlers in node_helper
            @sdetweil Wow excelent advice thank you. I will try that.! I think something else may be going on. As mentioned in my original post, I was able to take several pictures with my camera and on a whim decided to add those to my dataset. When i tried to run the encode program I got a message that the module could not be found, even after running a ls and staring at the engode program it claimed it could not be found. I’m starting to think I may have a corupt install. I am not sure what to do but I might flash another SD card and try a fresh install. Thanks for all your help!
              @danningson you ARE in the root of the module folder when you did npm run encode, right??
              cd ~/MagicMirror/modules/MMM-Face-Reco-DNN
              then you can run encode per the instructions
              npm run encode
                danningson
                Correct. I actuallly tride it from the MMM-Face-Reco-DNN and got the error message. I then went to tool and say the file and ecen tried to run it from there but got the same message.
                  @danningson this could be because of the need for the python virtual environment not being set up
                  I know he made a bunch of changes recently which require the venv…
                    @sdetweil Hi Sam - first, thank you for your time and expertise. I really do appreciate all the help. looks like you were right. I went back and ran the script again and noticed the environment additions. After running those I was able to run the encode.py program and it added several of the new pics i took. To further my troublshooting i added several classes as unknow. My thought was if the camera is seeing me but not recognizing me at least those moduels would show up and tell me the program was working correctly. Unfortunatly I got no reaction when looking into the camera either known or unknown. the camera is still wotking with the libcamera-still -o test.jpg so I am not sure why the program is failing to pic up anything. Again, thanks for your help
                      @danningson is mm running under that venv?
                        @sdetweil I’m not sure. I typed in env and got back a whole bunch of stuff i don’t understand
                          @danningson usually the terminal window prompt has the active python venv name prepended
                          (base) here on my system
                          (base) sam@sams:~/MagicMirror$
                            @sdetweil Ah, this pi is only intended for the mirror so i simply named it mm
                            mm@raspberrypi:~/MagicMirror $
                              @sdetweil I just ran the install script again and now i get this:
                              (python-facereco) mm@raspberrypi:~/MagicMirror $
                                @danningson ok, and NOW does facereco work?
                                  @sdetweil sorry, I should have included that in my response. No sadley I get no recognition or even an unknown face. The items with classes do not show, which is correct but it is as if the cammera is not seeing anything but I know it works.
                                    @sdetweil I came up with the briliant ide a to reboot the pi and now the (python-facereco) is gone as well. and yes, still no reaction from the camera
                                      @danningson you need to add the venv setup to the ~/.bashrc
                                      so it’s always set when a script is run
                                        @sdetweil It works!! Thank you for all your help! although i am back to nat having the (python-facereco) anymore it works and recgonizes both my wife and myself.
                                        Thanks for your time and and expertise on this.
                                          @danningson awesome
