    MM Installed, npm run start error
    4 Posts 2 Posters 763 Views 2 Watching
    • E Offline
      eitan
      Hi All,
      I am running on Pi 3,
      installed the PI OS lite (2023-12-05-raspios-bullseye-arm64-lite.img) and fully updated.
      after installing the Node.js as instructed in Manual installation, the command git clone… did not work, got the error: “git: command not found”, installed git using the command sudo apt install git, after that the command “git clone https://github.com/MichMich/MagicMirror” worked and all other commands until “npm run start”, where I get the error:
      pi@xxx/etc/apt/keyrings/MagicMirror $ npm run start
      > magicmirror@2.25.0 start
      sh: 1: ./node_modules/.bin/electron: not found
      Can anybody help on this?
        sdetweil @eitan
        @eitan mm needs full, not lite. must have graphics desktop
        once you have the right os
        you can do
        cd ~/MagicMirror
        npm install electron@26.2.4
        • E Offline
          eitan @sdetweil
          Thanks,
          I thought MM could run on a small system, save some disk space,
          Will update the OS.
            sdetweil @eitan
            @eitan the doc says full
