    Calendar module not showing events (fetch error)
    3 Posts 3 Posters 915 Views 3 Watching
    • N Offline
      nakulbende
      Using the default calendar module to display events - the same config worked for a while. I updated MM, and this does not work anymore. Getting the following issue regardless of which link I have in config - I checked and the cal links are working.
      I am using a RPi, MM is up to date. Thanks for all the help community!
      [23.12.2023 22:22.14.151] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/en.indian%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 3600000
      [23.12.2023 22:22.14.157] [ERROR] Whoops! There was an uncaught exception...
      [23.12.2023 22:22.14.168] [ERROR] ReferenceError: fetch is not defined
          at fetchCalendar (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:58:3)
          at CalendarFetcher.startFetch (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:103:3)
          at Class.createFetcher (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:80:11)
          at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:21:9)
          at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:104:11)
          at Socket.emit (node:events:513:28)
          at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
          at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:703:39
          at process.processTicksAndRejections (node:internal/process/task_queues:78:11)
      [23.12.2023 22:22.14.169] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [23.12.2023 22:22.14.170] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      Here is my config for this module:
      // Calendar
       				//header: "Calenar",
       					colored: true,
       					maximumNumberOfDays: 60,
       					maximumEntries: 12,
       					displaySymbol: true,
       					timeFormat: "absolute",
       					broadcastPastEvents: true,
       					showEnd: false,
       					wrapEvents: false,
      	 						//symbol: "fas fa-glass",
      	 						//maximumEntries: 4,
      	 						url: 'https://calendar.google.com/calendar/ical/en.indian%23holiday%40group.v.calendar.google.com/public/basic.ics',
      	 						//color: "#c97dff" // #ff8989, #ffc386, #f9ff99 is red, orange and yellow
      	 						symbol: "fas fa-heart",
      	 						maximumEntries: 4,
      	 						color: "#a1ffb6",
      	 						url: "XXX",
      	 						symbol: "fas fa-birthday-cake",
      	 						maximumEntries: 4,
      	 						color: "#ff8989",
      	 						url: "XXX",
      BKeyportB KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
      • BKeyportB Offline
        BKeyport Module Developer @nakulbende
        @nakulbende Looks like you might have missed a step in installing your mirror from my point of view. the module “fetch” is missing, which indicates “npm install” may not have been run from the MagicMirror directory. How did you install?
        • KristjanESPERANTOK Offline
          KristjanESPERANTO Module Developer @nakulbende
          It could also be that node is too old. Check whether you have node 18 or newer with: node -v
