    Hello everyone, do you know if there is an MM module for rugby
    105 Posts 5 Posters 166.0k Views 6 Watching
      manu85340 @mumblebaj
      @mumblebaj do you think that in apisports I can put the top 14 and six nations so that they are displayed in the module?
      • mumblebajM Offline
        mumblebaj Module Developer @manu85340
        @manu85340 Hi, no, the apiSports API only takes a single league as input.
          Manu85 @mumblebaj
          @mumblebaj shit ! Do you think it is possible to remove the lines of rows and columns that look like an Ecxel table? and I think it would be preferable to make a single column of the difference of the points scored and conceded to have the goal-average: GA-GF, it would be clearer to read and it would take up less space, thank you, I think your module is going to be a real success
            Manu85 @mumblebaj
            @mumblebaj Hi ! it could look like this without column “B” which indicates the offensive and defensive bonuses
              mumblebaj Module Developer @Manu85
              @Manu85 You can set the below in your css/custom.css which would eliminate the borders if you prefer not to see them.
              .MMM-Rugby #MMMRugby-rankingTable td,
              .MMM-Rugby #MMMRugby-rankingTable th,
              .MMM-Rugby #rankingMatchesTable td,
              .MMM-Rugby #rankingMatchesTable th {
                border: none;
              Do you mean you would prefer to see a Goal difference and not the Goals For and Goals Against columns?
                sdetweil @mumblebaj
                @mumblebaj said in Hello everyone, do you know if there is an MM module for rugby:
                just fyi, you don’t have to duplicate the major part of the selector clause
                .MMM-Rugby #MMMRugby-rankingTable td, th,
                .MMM-Rugby #rankingMatchesTable td, th {
                           border: none;
                should have worked too…
                  Manu85 @mumblebaj
                  @mumblebaj thank you for your help and thank you also to @sdetweil and indeed only one idiot with the goal difference in the place of the two columns goals scored and goals conceded
                    Manu85 @sdetweil
                    @sdetweil Thanks Sam for your help
                      @Manu85 said in Hello everyone, do you know if there is an MM module for rugby:
                      idiot
                      :beaming_face_with_smiling_eyes:
                      I have remove GF and GA and added GD. You can update the module.
                        Manu85 @mumblebaj
                        @mumblebaj great, a big thank you, however I won’t be able to see it until tomorrow because I have reached the number of API keys for the day:sleepy_face:
                          @Manu85 You can do 1000*60*30 which is update every 30 minutes which gives you 48 calls 84 calls for the day.
                            Manu85 @mumblebaj
                            @mumblebaj Yes, but I tried a lot of modifications today and every time I refresh the MM, I think it makes an API call
                              @Manu85 Yes, that is correct. If you not making changes to the MMM-Rugby module then switch to the free option instead.
                              M 3 Replies Last reply Reply Quote 0
                                Manu85 @mumblebaj
                                @mumblebaj Yes you’re right that’s what I should have done…I’m stupid not to have thought of that before
                                  Manu85 @mumblebaj
                                  @mumblebaj I think that if it is possible you can delete the column circled in blue given what it is in the title, it will ultimately make a PERFECT module
                                    Manu85 @mumblebaj
                                    @mumblebaj on the other hand it’s strange I don’t have the six nations, I put you my config.js, did I make a mistake?
                                            		module: "MMM-Rugby",
                                            		disabled: false,
                                                            updateInterval: 1000*60*60*24,
                                                            rotateInterval: 60000,
                                                            sport: "mrs",
                                                            rankingLimit: 10,
                                                            matchesLimit: 10,
                                                            matchesOlderThan: 7,
                                                            competitions: ["Six Nations"],
                                                            collectionType: "free"
                                      @Manu85 Yes, sport must be mru to get Six Nations. You on Mens Rugby Sevens.
                                        @Manu85 That info is helpful when using mru and no filter.
                                          Manu85 @mumblebaj
                                          @mumblebaj ok, I put ‘mru’ but I have other matches in addition to the six nations in the table
                                          mumblebajM 2 Replies Last reply Reply Quote 0
                                            @Manu85 Was a typo. Fixed. Also added an option if you only have a single competition listed then the competition column will be omitted else if more than one competition then it will be displayed.
                                            I am off to bed now. If any further issues or enhancements please raise on the github page and I will review.
                                            • 6
                                            • 3 / 6
