    pm2 error
    1 Posts 1 Posters 1.2k Views 1 Watching
    • Q
      qqqqqqqq
      I tried to autostart MM2 using pm2 & it actually even worked once (from here ).
      But Now it doesn’t even start.
      here is the data from the log file.
      [STREAMING] Now streaming realtime logs for [mm] process
      0|mm       | Initializing new module helper ...
      0|mm       | No helper found for module: compliments.
      0|mm       | No helper found for module: currentweather.
      0|mm       | No helper found for module: random_quotes.
      0|mm       | All module helpers loaded.
      0|mm       | Starting server op port 8080 ...
      0|mm       | Server started ...
      0|mm       | Connecting socket for: updatenotification
      0|mm       | Connecting socket for: calendar
      0|mm       | Starting node helper for: calendar
      0|mm       | Connecting socket for: newsfeed
      0|mm       | Starting module: newsfeed
      0|mm       | Connecting socket for: MMM-Remote-Control
      0|mm       | Starting node helper for: MMM-Remote-Control
      0|mm       | Connecting socket for: MMM-SystemStats
      0|mm       | Connecting socket for: stocks
      0|mm       | stocks helper started ...
      0|mm       | Sockets connected & modules started ...
      0|mm       | Xlib:  extension "XInputExtension" missing on display ":1.0".
      0|mm       | Xlib:  extension "RANDR" missing on display ":1.0".
      0|mm       | Launching application.
      0|mm       | ERROR! Could not find main module js file.
      0|mm       | Create new calendar fetcher for url: http://calendar.google.com/calendar/ical/....ics - Interval: 300000
      0|mm       | Create new calendar fetcher for url: http://localhost:8080/modules/Cals/FbBirthday.ics - Interval: 300000
      0|mm       | Create new calendar fetcher for url: http://calendar.google.com/calendar/ical/e....ics - Interval: 300000
      0|mm       | Create new news fetcher for url: https://news.google.com/news?cf=all&hl=en&pz=1&ned=in&output=rss - Interval: 300000
      Something to do with this perhaps?
